Dreamweaver CS6 quits unexpectedly, MAC OSX 10.8.2
Jan 6, 2013 10:01 AM
Tags: #mac #osx #dreamweaver #cs6 #quits #unexpectedly #10.8.2
Cann anyone help with thus? Cannot start the applicationb after install. Here is the dump:
Process:         Dreamweaver [938]
Path:            /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/Dreamweaver
Identifier:      com.adobe.dreamweaver-12.0
Version:         12.0.0.5808 (12.0.0)
Code Type:       X86 (Native)
Parent Process:  launchd [193]
User ID:         501
Date/Time:       2013-01-06 12:54:25.814 -0500
OS Version:      Mac OS X 10.8.2 (12C60)
Report Version:  10
Interval Since Last Report:          664643 sec
Crashes Since Last Report:           24
Per-App Interval Since Last Report:  96 sec
Per-App Crashes Since Last Report:   1
Anonymous UUID:                      BA9D8583-897F-83CD-A3AB-505FF08DD33B
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '+[SIMBL logMessage:atLevel:]: unrecognized selector sent to class 0xc48d160'
    Jan 6, 2013 10:21 AM   in reply to jamesdeluca
    What Mac? Looks like a problem with the OS itself, disk access on a mapped folder/ alias more specifically. Also provide the full list for the crashed Thread 0 from the logs as explained here:
    Working with your Operating System’s Tools
    Mylenium
    Jan 6, 2013 12:03 PM   in reply to Mylenium
    Moving this discussion to the Dreamweaver General forum.
    Jan 25, 2013 11:58 AM   in reply to jamesdeluca
    Recommend first updating Dreamweaver to the latest version. Go to Help > Updates, which will check for any available updates, and then download and install them for you.
    If updating does not resolve the issue, you might try clearing your Dreamweaver cache: http://forums.adobe.com/thread/494811
    Or the entire Configuration folder (a.k.a. preferences): http://helpx.adobe.com/dreamweaver/kb/restore-preferences-dreamweaver- cs4-cs5.html
    Feb 28, 2013 12:51 AM   in reply to jamesdeluca
    Found the solution !!
    Sometimes you need to look somewhere else for the solution so I googled the error line and it came out other osx users are suffering from crashes in other apps or games etc. So i found out its about SIMBL...
    In library >Application Support > SIMBL
    just rename it to something else and DW Works !!!
    Mar 3, 2013 5:14 AM   in reply to SercoTec
    Hello Serco Tec,
    I'm having the same problem described above.
    In your post you mention this SIMBL... I have looked in both Libraries and find no such file in the Applications Support folder. Spotlight doesn't find it either.
    I would appreciate it if you clarify the exact location of this file.
    Thank you,
    JV
    Mar 3, 2013 5:42 AM   in reply to Jaime Viñas
    Hi Jaime,
    Check if you are on ML 10.8.2 (Because i do not know if this problem occurs in SL or previous versions of ML.
    Be sure you are getting the same error in your error report page saying : "Application Specific Information:
    *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '+[SIMBL logMessage:atLevel:]: unrecognized selector sent to class..."
    Be sure you can see all the library items (by default library and items are invisible, ask google how to reveal.
    If all revealed and SIMBL is still not there try installing it from http://www.macupdate.com/app/mac/44354/easysimbl
    Try running the program crashing. If it still occurs then find SIMBL in your library and rename to something else.
    I hope it helps...
    Mar 3, 2013 12:47 PM   in reply to SercoTec
    SercoTec,
    Thanks for your reply.
    It turns out the preferences were damaged.
    Re-named them and the program restarted normally... now back to work!
    JV
