mozzer503
Diskspace error in Photo Downloader
Jan 6, 2013 8:06 PM
Tags: #problem #bridge_cs5 #downloader_problem
Hey
I have the photo downloader that comes with Bridge 4.0.5.11 on OSX 10.8.2.
I use the Advanced Dialog.
The tool is set to:
Create customer name subfolders
Rename files using Shot Date yymmdd plus a number
Convert to DNG
Delete original files is OFF
Save Copies is set
Apply Metadata template is set.
Both the DNG and the original raw are downloaded to a Synology NAS drive. The drive originally had 8TB of space (actual not available) and everything worked fine.
I've updated the NAS to 12TB of space and now the downloader fails. After about 90 or so copies it reports that the NAS is running low on disk space and the operate is aborted.
The NAS is not low on disk space, and removing the "save copies" option and then performing the operation manually works fine.
Any clues as to what's going wrong?
  • Omke Oudeman
    Nov 27, 2004
    Jan 7, 2013 5:14 AM   in reply to mozzer503
    Bridge often gets in trouble on a network environment.
    First restart Bridge holding down option key and choose reset preferences (sets preferences back to default so you have to reset custom settings).
    And maybe deleting the plist file for Photodownloader also will help you.
    Quit Bridge and Photodownloader an go to the user library (by default hidden per OS10.7, use menu go and press option to reveal this library)
    user (your name) / library / Preferences / find and manual delete the Photodownloader plist file (com.adobe.photodownloader.plist) and try again (it will refresh itself after restarting photodownloader, but you need to reset your custom settings.
  • Omke Oudeman
    Nov 27, 2004
    Jan 21, 2013 12:30 PM   in reply to mozzer503
    Seems odd that the only times I reboot my mac are to refresh Flash and now Photoshop
    I always understood that rebooting computers was a good thing to do, refreshing a lot of stuff (and in case of overnight put it to rest, saves energy and causes less wear), Personally I have set my computer to auto shut down after finishing Back up (at my command when ready in using my Mac) and auto start up on a timer base and meanwhile as one of the first automated tasks to run the auto pilot of the Cocktail script for maintenance (clearing caches and repairing permissions etc.)
    I really think this keeps my Mac in a healthy state instead of letting it run day and night, And regarding to myself, a good night sleep and a nice breakfast gives me a good start also
