cammello005
monitor turns blue at start of CS6
Jan 8, 2013 5:48 AM
hi there, i've allready installed my copy of CS6.
when it runs all of window of my desktop turns in a blue tint included of course the image i'm working on.
what have i tu adjust?
i had no problems wirh previus version (i upgraded from CS3 extended, it's a long jump)
thanks to all can help me
happy new year
stefano
  • Noel Carboni
    Dec 23, 2006
    Jan 8, 2013 6:35 AM   in reply to cammello005
    I've seen this reported before.
    It has to do with having both GPUs of a dual setup enabled.  I believe the workaround was to disable the low power GPU in the operating system so that Photoshop would only use the high powered GPU.
    -Noel
    Jan 8, 2013 8:11 AM   in reply to cammello005
    With a dual-GPU setup, one will usually disable, say the Intel GPU in the system's BIOS.
    If one has such a setup on a desktop, in lieu of a laptop, there might be jumpers, or DIP switches on the MoBo, but I would still check the BIOS first.
    Jan 8, 2013 8:58 AM   in reply to cammello005
    If you are not comfortable with BIOS, you may be able to disable the lower-powered (unused) GPU from within Device Manager on your computer. The real fix is to disable it via BIOS though if it is an option.
  • Noel Carboni
    Dec 23, 2006
    Jan 8, 2013 6:23 PM   in reply to cammello005
    I honestly don't know how, specifically.  I don't have such a system.  I'm only passing along what I've read here.
    -Noel
    Jan 8, 2013 7:22 PM   in reply to cammello005
    Might be best to do a web search with make of computer and ask something like "disable second video card".
