I am running PS 6 for win64. Today I suddenly starting getting an error message saying that my ICC profiles are invalid. When I try to write a raw file to .tif after it has been converted to black/white, I get a corrupted .tif file.
So I have been trying to reinstall these profile files using the ones for PS4 as provided on your web site. But they won't install properly, and the problem persists.
What should I do?
Mike Stratil
This has nothing to do with the Adobe standard profiles. You have a flakey monitor or printer profile. Check your system's global color management settings, your printer setup and your graphics driver. Reinstall CS6 completely after running the Creative Suite Cleaner Tool
Mylenium
That's the only folder on my system. By "try" I meant, "that's where you'll probably find them, unless you've got some unusual non-standard set-up".
I read about another folder, called "Recommended" the other day. I think it's an Adobe-only thing, and I seem to remember that it's contained within the above-mentioned folder anyway. You could always just search your entire drive (including hidden folders) for *.ICM and *.ICC.
Sorry, I thought you were looking for profiles.
Plug-ins are located elsewhere. Look in C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins and subdirectories for Photoshop 64-bit plug-ins.
For Photoshop 32-bit, look in C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Plug-ins
For Bridge, C:\Program Files\Adobe\Adobe Bridge CS6 (64 Bit)\Plug-Ins and C:\Program Files (x86)\Adobe\Adobe Bridge CS6\Plug-Ins
For both, C:\Program Files\Common Files\Adobe\Plug-Ins and C:\Program Files (x86)\Common Files\Adobe\Plug-Ins
Be careful what you do though. Don't break anything.
FAILURE!
I have just finished implementing Mylenium's recommended procedure for correcting the problem I have. I have also installed the latest updates. But the problem persists! That is, a file converted to black and white in Bridge 6 comes out with a red cast and the following notice:
"The embedded ICC profile cannot be used because the ICC profile is invalid. Ignoring the profile."
What can I do now?
Well, for years I have been going to the HSL/Greyscale button and selecting greyscale. That is what I meant by B/W. This may not be B/W technically, but it generates a B/W image when the file is exported.
So the current situation is a striking deviation from what I have experienced with CS6 for a long time. Now I get a file with a huge color cast (red) that I never got before a few weeks ago. Something has gone wrong.
There is no HSL/Greyscale button in Bridge. I'm guessing you mean the HSL/Greyscale tab in Camera Raw, launched by double-clicking on a raw file in Bridge. It sounds like your problem is with Camera Raw.
You said initially: "When I try to write a raw file to .tif after it has been converted to black/white, I get a corrupted .tif file"
Can you say what version of Camera Raw you are running? If you look at the attached jpeg, there is an arrow pointing to the version info, top left.
At the bottom, the working colour space is shown. You can change it by clicking on it, then changing it to sRGB or AdobeRGB, or whatever you want.
Are you then saving the TIFF with Camera Raw's Save button (shown bottom left)? Or are you opening the conversion in Photoshop?
Hi Yammer,
You are right, I should have said that I was working in CR.
I am using CR 7.3.
I have just tried changing to sRGB and saving to .TIFF with the button at lower left side.
SUCCESS! The file is now shown as I intended in grayscale.
Apparently at some point I inadvertently changed the color space.
Your help has been extremely valuable. Thanks a lot.
Mike
North America
Asia Pacific
