ngovanhinh
Login redirect page error
Jan 8, 2013 8:18 PM
After login success or logout from my current page (i.e. "ic_detail.asp?ID=372", this page gets a variable from another page), it failed to redirect to that current page . I got the following error:
There is a problem with the page you are trying to reach and it cannot be displayed.
Error Type:
ADODB.Field (0x800A0BCD)
Either BOF or EOF is True, or the current record has been deleted. Requested operation requires a current record.
/idc/asp/ic_detail.asp, line 266
Here is the page code invovled:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="65001"%>
' *** Logout the current user.
MM_Logout = CStr(Request.ServerVariables("URL")) & "?MM_Logoutnow=1"
If (CStr(Request("MM_Logoutnow")) = "1") Then
  Session.Contents.Remove("MM_Username")
  Session.Contents.Remove("MM_UserAuthorization")
  MM_logoutRedirectPage = Request.ServerVariables("URL")
  ' redirect with URL parameters (remove the "MM_Logoutnow" query param).
  if (MM_logoutRedirectPage = "") Then MM_logoutRedirectPage = CStr(Request.ServerVariables("URL"))
  If (InStr(1, UC_redirectPage, "?", vbTextCompare) = 0 And Request.QueryString <> "") Then
    MM_newQS = "?"
    For Each Item In Request.QueryString
      If (Item <> "MM_Logoutnow") Then
        If (Len(MM_newQS) > 1) Then MM_newQS = MM_newQS & "&"
        MM_newQS = MM_newQS & Item & "=" & Server.URLencode(Request.QueryString(Item))
      End If
    Next
    if (Len(MM_newQS) > 1) Then MM_logoutRedirectPage = MM_logoutRedirectPage & MM_newQS
  End If
  Response.Redirect(MM_logoutRedirectPage)
End If
<!--#include file="../Connections/cosodulieu.asp" -->
<!--#include file="../Connections/login.asp" -->
Dim Mydoc__MMColParam
Mydoc__MMColParam = "1"
If (Request.QueryString("ID") <> "") Then
  Mydoc__MMColParam = Request.QueryString("ID")
End If
Dim Mydoc
Dim Mydoc_cmd
Dim Mydoc_numRows
Set Mydoc_cmd = Server.CreateObject ("ADODB.Command")
Mydoc_cmd.ActiveConnection = MM_cosodulieu_STRING
Mydoc_cmd.CommandText = "SELECT * FROM Incoming WHERE ID = ?"
Mydoc_cmd.Prepared = true
Mydoc_cmd.Parameters.Append Mydoc_cmd.CreateParameter("param1", 5, 1, -1, Mydoc__MMColParam) ' adDouble
Set Mydoc = Mydoc_cmd.Execute
Mydoc_numRows = 0
Dim rsuserdata__MMColParam
rsuserdata__MMColParam = "1"
If (Session("MM_Username") <> "") Then
  rsuserdata__MMColParam = Session("MM_Username")
End If
Dim rsuserdata
Dim rsuserdata_cmd
Dim rsuserdata_numRows
Set rsuserdata_cmd = Server.CreateObject ("ADODB.Command")
rsuserdata_cmd.ActiveConnection = MM_login_STRING
rsuserdata_cmd.CommandText = "SELECT * FROM login WHERE username = ?"
rsuserdata_cmd.Prepared = true
rsuserdata_cmd.Parameters.Append rsuserdata_cmd.CreateParameter("param1", 200, 1, 50, rsuserdata__MMColParam) ' adVarChar
Set rsuserdata = rsuserdata_cmd.Execute
rsuserdata_numRows = 0
' *** Validate request to log in to this site.
MM_LoginAction = Request.ServerVariables("URL")
If Request.QueryString <> "" Then MM_LoginAction = MM_LoginAction + "?" + Server.HTMLEncode(Request.QueryString)
MM_valUsername = CStr(Request.Form("txtusername"))
If MM_valUsername <> "" Then
  Dim MM_fldUserAuthorization
  Dim MM_redirectLoginSuccess
  Dim MM_redirectLoginFailed
  Dim MM_loginSQL
  Dim MM_rsUser
  Dim MM_rsUser_cmd
  MM_fldUserAuthorization = ""
  MM_redirectLoginSuccess = Request.ServerVariables("URL")
  MM_redirectLoginFailed = Request.ServerVariables("URL")
  MM_loginSQL = "SELECT username, pass"
  If MM_fldUserAuthorization <> "" Then MM_loginSQL = MM_loginSQL & "," & MM_fldUserAuthorization
  MM_loginSQL = MM_loginSQL & " FROM login WHERE username = ? AND pass = ?"
  Set MM_rsUser_cmd = Server.CreateObject ("ADODB.Command")
  MM_rsUser_cmd.ActiveConnection = MM_login_STRING
  MM_rsUser_cmd.CommandText = MM_loginSQL
  MM_rsUser_cmd.Parameters.Append MM_rsUser_cmd.CreateParameter("param1", 200, 1, 50, MM_valUsername) ' adVarChar
  MM_rsUser_cmd.Parameters.Append MM_rsUser_cmd.CreateParameter("param2", 200, 1, 50, Request.Form("txtpassword")) ' adVarChar
  MM_rsUser_cmd.Prepared = true
  Set MM_rsUser = MM_rsUser_cmd.Execute
  If Not MM_rsUser.EOF Or Not MM_rsUser.BOF Then
    ' username and password match - this is a valid user
    Session("MM_Username") = MM_valUsername
    If (MM_fldUserAuthorization <> "") Then
      Session("MM_UserAuthorization") = CStr(MM_rsUser.Fields.Item(MM_fldUserAuthorization).Value)
    Else
      Session("MM_UserAuthorization") = ""
    End If
    if CStr(Request.QueryString("accessdenied")) <> "" And false Then
      MM_redirectLoginSuccess = Request.QueryString("accessdenied")
    End If
    MM_rsUser.Close
    Response.Redirect(MM_redirectLoginSuccess)
  End If
  MM_rsUser.Close
  Response.Redirect(MM_redirectLoginFailed)
End If
<h2>CHI TIẾT VĂN BẢN</h2>
<table width="800" border="0">
  <tr>
    <td width="162" class="Head">ID:</td>
    <td colspan="2" class="body"><%=(Mydoc.Fields.Item("ID").Value)%></td> ' Line 266 is here
    </tr>
  <tr>
Please help me to modify the code to redirect to my current page after login or logout.
    Jan 9, 2013 10:50 AM   in reply to ngovanhinh
    The error means your recordset is empty.
    You are setting the redirect url here:
    That only gives the base url. You need to append the existing query string.
