Install CS2 from link - Error Activation Server Unavailable
Jan 9, 2013 12:07 AM
I've downloaled CS2 for Windows from the link in "Error: Activation Server Unavailable"  but when I run the setup .exe its asking for cd 2 to be loaded!  - "Cd 2" seems to the problem - I've checked the size and it appears to be correct (I've re-downloaded it 3 times!).
Has any one else had this issue?
Only solution Adobe can suggest is to buy CS6!
    Jan 9, 2013 4:15 AM   in reply to AndyJSM
    No, Adobe does not suggest you to buy CS6 if you already have a genuine CS2 product, otherwise, we would have not given you that option. Now, if we talk about the download, may be its something that can be worked on.
    I would suggest you to download the same using a different browser or try downloading it onto a different machine and then bring it over and try installing the same.
    Check if that helps.
    Let me know if you still face the same issue.
    Jan 9, 2013 4:24 AM   in reply to AndyJSM
    Probably you have not removed correctly a previous cs2 installation
    Jan 9, 2013 5:32 AM   in reply to Arpit Kapoor
    You might also follow the suggestions mentioned under the below forum post. Few user issues have been resolved by following it.
    http://forums.adobe.com/message/4979917#4979917
    Message#9
    Jan 9, 2013 6:39 AM   in reply to AndyJSM
    There is a bug in the cd2 extraction. It create a new folder "Creative suite" intead of copying files in "creative suite CS2"
    Jan 9, 2013 8:40 AM   in reply to AndyJSM
    I was able to install from the downloaded files by downloading all the files into the same folder before starting the install. Every thing works except illustrator. when I try to launch I get "runtime error"
    Jan 9, 2013 4:55 PM   in reply to rob170
    Please see post #11 in http://forums.adobe.com/message/4919014#4919014?sdid=KCHDS where this topic has been discussed.
