Hi there,
Now, when I launch InDesign CS6, it crashes with this error detail from event viewer.
Date/Time: 2013-01-09 10:03:35.606 +0000
OS Version: Mac OS X 10.8.2 (12C60)
Report Version: 10
Interval Since Last Report: 194113 sec
Crashes Since Last Report: 39
Per-App Interval Since Last Report: 44975 sec
Per-App Crashes Since Last Report: 4
Anonymous UUID: F843AE4F-0E7E-9223-C543-C50B8A905FD4
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
I've deleted preference file, and still keeps bombing out.
Need help ASAP....
I'm having the same problem since today with almost the same error details. I'm using Adobe Cloud. Reinstalling, deleting preferences and other cache/registry files (as recommended in earlier posts) is not working. Please help.
My log: http://pastebin.com/r3ieNaYx
This helped me. http://helpx.adobe.com/indesign/kb/indesign-preferences-support-file-l ocations.html
I deleted the files (empty trash can with Command pressed), started InDesign pressing Shift+Control+Option+Command and reset all preferences. Now working again...
I'm sorry you don't find "no promises" satisfactory. Crashes are complex, and most of us have very little expertise in the inner workings of ID and the OS -- we're just users. SOme crashes have distinctive signatures, and those we have learned to recognize, others are more cryptic and baffle even our most expert helpers.
Of course we can't help at all unless you post the reports as requested.
The only folks on the forums who actually work for Adobe have Staff badges next to their names. That shouldn't discourage you though, our regulars have dozens of years of real world experience working with the applicationa and solving problems (we have a much better record, I think, than Tech Support on the phone
Nothing specific. Paul didn't post the part that would tell us what was happening, and jankoroleva seems to have found a solution, thogh that report shows a need to update ID to the lates patch, whcih may or may not have anythng to do with the issue.
That said, while some crashes are the same, many look like the same thing and are not, so you should post your own crash report on pastebin.com and put a link here or in a new thread that you start just for that purpose (and give us full details about ID version, OS, whether a clean install or an upgrade to the OS, and if you tried to migrate the applications).
That looks familiar, but that's not good news. That's one of the one's I don't have a solution for. John Hawkinson is our resident expert on these, and perhaps he'll join us.
In the meantime, do you have any third party plugins installed, or a font manager? Did ID ever launch for you?
Are you able to run Adobe Extension Manager? If so, try unchecking the PMWelcomeScreen plugin so it doesn't launch on startup and try starting ID again. I believe that plugin is associated with the ShuksanInit(IStartupScreen* (*)(), IPlugIn*) + 28162 line just before the protective shutdown.
I think we're seeing quite a few problems with 10.8 that may be related to a change in Apple code (just a gut feeling) that happened after CS6 was tested and released.
david668 wrote:
- InDesign does launch most of the time, but once it starts crashing this way, it won't launch successfully until the computer is rebooted
That sounds like it could be related to some other program that you start up sometime during your session, but that is not launched on startup.
Paul,
There is a LOT more to a crash report than what's at the top of this page. Either you didn't get it all, or somebody edited your post. You can see waht you are missing by looking at the other reports in the links. You should post the whole thing again on pastebin.com and put a link here.
I think you're skating on thin ice. But I'm a Windows user, and I haven't used suitcase since 2001 when I worked in a Mac-based shop. It gave me so much trouble then that I swore I'd never install it on a system I own, but obvioulsly others, like Bob, feel differently. He uses it one both paltforms and loves it.
North America
Asia Pacific
