suvasishm
CQ5 image gallery component
Jan 9, 2013 2:46 AM
Tags: #cq5.5
I'm a newbee in CQ5. I need to create an image gallery similar to http://goo.gl/RGBXs. How can I proceed towards that?
I was thinking of taking a DAM folder path from the content author as an input and using that I would create the block by iterating all the images contained within that folder. Is that a correct way? If so, what API I can use to iterate through the image files contained in a DAM folder?
Any help or response is highly appretiated.
Thanks.
    Jan 13, 2013 5:22 PM   in reply to suvasishm
    Assuming resource pointing to /content/dam/myproject/photo_gallery  something like below should work
    Iterator<Resource> assetList=resolver.listChildren(resource);
            while (assetList.hasNext()) {
                Resource child = assetList.next();
                Asset asset = child.adaptTo(Asset.class);
                 if (asset != null) {
    Feb 5, 2013 4:02 PM   in reply to suvasishm
    Hi suvsm, now that you have the child node (the image in the DAM), what is the subsequent code to display the image.
    And did the image display properly on the publisher?
    Thanks!
    Jason
    Feb 6, 2013 10:57 AM   in reply to Sham HC
    Hi Sham - I followed this style ofiginally too but I could not get the image to display.
    Can you fill in the ... in your post, please?
    my code below doesn't seem to work:
    Image myImage = new Image(asset or resource - you named it child)
    image.setSelector(".img");
    image.draw(out);  //this doesn't work
    and even just using the image.getSrc() in my image tag,
    <ima src="<%=image.getSrc()%>/>
    will not work properly if my the path to the DAM, /content/dam/* is blocked on the publisher.
    Feb 6, 2013 10:45 AM   in reply to suvasishm
    Hi suvsm!  Thanks for replying!
    I've done the same code too...which helps confirms that I'm not going crazy and my approach isn't totally wrong.
    But if this works for you then you also know that the path to your DAM, "/content/dam/hnodemo/photo_gallery", is open to the world on your publisher, right?
    Cheers!
    Jason
