Cannot create Clipping Mask on 3 separate text objects
Jan 9, 2013 5:40 AM
Tags: #clipping_masks
Hi All
I have created custom text, so that each letter in my 3 letter word is a separate compound object.
Now I have made a filled (with gradient) ellipse and rectangle behind the text to create a clipping mask with all 3 text objects. (see image1)
However, when I select all the objects and select: object>clipping mask >make, it only mask the one letter, which is the one on top. (see image 2)
However, when I group the 3 letters together, it does not create a clipping mask at all, it shows nothing... (see image 3)
How do I ake all 3 letters be in the mask?
Thank you
Here is a link to the .ai file: http://lamininbeauty.co.za/david/STS.ai
    Jan 9, 2013 6:03 AM   in reply to DexterDave
    Dave,
    You may select all the letters and Object>Compound Path Make, then use that as the Clipping Path for the Clipping Mask.
    Jan 9, 2013 6:05 AM   in reply to DexterDave
    Take your three letter shapes, and combine them into a coumpond path. Object > Coumpound Path > Make
    Group the two gradient shapes, then select coumpound path and group.
    object > clipping mask >make will now work : like this
    Jan 9, 2013 11:48 AM   in reply to DexterDave
    For my part you are welcome, Dave.
    For many purposes, such as a normal simple drop shadow, you can:
    1) Create a copy of the text,
    2) Lock the original, and use the copy for the Clipping Mask,
    3) Use the underlying original for other purposes.
    I am a bit unsure what you mean by a drop shadow (vertically flipped) of that text.
    An image/screenshot and/or a more detailed description might help helpers that are a bit slow in the uptake.
    Jan 9, 2013 12:28 PM   in reply to DexterDave
    Dave, do you mean this sort of effect?
    If so, I just dragged a copy (alt+drag), then grabbed the center top control handle and dragged it downward until I was happy. Then skewed it a bit.
    From there you can recolor it black (or whatever), add a gussian blur or feather, or whatever.
    Mike
    Jan 9, 2013 2:23 PM   in reply to DexterDave
    Ah, Mark. very nice.
