Hello, I am trying to find a solution for the following on the animation I am working on.
When you mouse over an area the center content show up but I can't find a solution so it return to the home image, the phone and building, or the initial state, any help would be appreciated.
Yes Murphy, that is what I want. I need it to return to the home image once the User mouse out. The circle pie is a design with six button and each button call the their external .swf that show in the middle, here is the code for one buttons, they are all the same, the only different is the url change, I don't know how to do so when you mouse out it return to the first image or index image
Here is the code:
on (rollOver)
contenido1.onEnterFrame = function ()
if (this._currentframe != 70)
this.nextFrame();
else
this.stop();
delete this.onEnterFrame;
} // end else if
on (rollOut)
if (this._currentframe != 1)
this.prevFrame();
else
this.stop();
} // end else if
on (rollOver)
loadMovieNum("c1.swf", 1);
on (release)
getURL("http://www.lancasterscworks.com", _blank);
If you are using loadMovieNum to load each different rollover image, then you need to use unloadMovieNum(1) to remove it when you rollout. If the home page image is also an externally loaded piece, another option could be to loadMovieNum the home page section for every rollout so that it replaces the current rollover image..
I can't really help without more information about how you've designed this relative to the home image showing. If it is also dynamically added then you would probably only need to use...
on (rollOut)
loadMovieNum("home.swf", 1);
where home.swf is the name of whatever file you use for the home image that appears.
If the home image is a permanent fixture in the design and is not loaded dynamically, then you probably only need to use...
on (rollOut)
unloadMovieNum(1);
I have one more question, if you take a look at the govemment entities, I need that one a little different, when you mouse over show the center those are logos with 4 link, when you mouse over return to home but how can i do to keep the mouse over a little timed so it show the link and you can click and go to their websites?
You would put the setTimeout call in the rollout function and it would end up calling a function that you place on the timeline. So on the button you could put...
on(rollOut){
var sto = setTimeout(unloadGov, 2000);
which will give a 2 second delay (2000 msecs) before it calls the unloadGov function that you will place in the timeline.
Since I don't know which approach you took for changing the images back, hopefully you can make it match what you did for the others...
function unloadGov(){
unloadMovieNum(1);
This works perfectly...
I also need another tip. I have another button that you mouse over and show an image with a button on the middle, when I click the button and want the Fancybox popup windowload, do I put that code on the flash and html or just one source?
Have you done anything like that click a section of the flash an a popup opens?
North America
Asia Pacific
