chrysotile
Adobe Acrobat 9.0 Pro Freezes (Mac OS 10.7.5)
Jan 9, 2013 1:29 PM
Tags: #macintosh #acrobat #adobe #lion #freezes #9.0
I am having a problem with Adobe Acrobat 9 Pro, version 9.5.2.
Whenever I open a PDF file, it frequently freezes and I am left
with the twirling color circle. Sometimes (less frequently), the
PDF file opens nicely. However, when I also save any changes
to a PDF file, it will also freeze and I am left with the twirling
color circle. If I wait several minutes sometimes, the twirling
will stop and the software returns to working. I have this
problem regardless of the size of file being either read or
modified.
An IT friend has installed, uninstalled, and reinstalled
Adobe Acrobat 9 Pro a couple of times in order to solve
this problme and doing so does not changed anuything.
My computer is a MacPro4,1. It  runs Mac OS X Lion 10.7.5
(11G63). It has a 2 X 2.26 GHz Quad-Core Intel Xeon
Processor and 16 GB 1066 MHz DDR3 memory. The
harddrive on which it is installed has 522 GB available.
Best wishes,
Paul
    Jan 10, 2013 2:32 AM   in reply to chrysotile
    [Moved the discussion to Acrobat Forum]
  • David Kastendick
    Apr 7, 2010
    Jan 14, 2013 11:30 AM   in reply to chrysotile
    I would suggest you try applying the 9.5.3 update first to see if the behavior improves.
    If it doesn't, you may want to run a Disk Permissions repair from the Disk Utility.
