kitmm
Playback and rendered video jumps up and down regularly and minutely
Jan 14, 2013 2:46 PM
Tags: #premiere #up_and_down_movement
A number of the sequences I've edited have a minute but noticible up-and-down movement.  For example, see http://www.youtube.com/watch?v=hely09sD6gY  You'll notice that only the video image moves up and down, not any of the still images or the StudioCrasher watermark.  I initially thought it was the source video I'd imported, but on a more recent project I've noticed that it also does it with footage from a secondary video camera.
I also note that this doesn't happen on the original source video in Premiere, just in the edit playback and in the exported video.  So, it has to be something in Premiere.
I've tried everything, including searching endless discussion boards, but I can't come up with a solution or a work-around.
Any ideas?
    Jan 14, 2013 3:15 PM   in reply to kitmm
    What are your export settings?
    Jan 14, 2013 8:50 PM   in reply to kitmm
    More questions to answer, for people to try and help http://forums.adobe.com/message/4200840
    Jan 15, 2013 9:56 AM   in reply to kitmm
    What sequence settings are you using?  Any effects added to the clips?
    Jan 17, 2013 10:32 AM   in reply to kitmm
    You sure you recorded progressive?  Have you tried an Interlaced sequence?
    Jan 17, 2013 10:34 PM   in reply to kitmm
    Weird, man.
    If you want to upload a clip, I can take a look here.
    http://www.depositfiles.com/en/
    Jan 20, 2013 7:43 PM   in reply to kitmm
    Your YouTube video is playing at 30 fps. While you edited the video at 25 fps.
    I think your export settings are the problem. Choose one at 25 fps and see if that will solve the shifting.
    Feb 6, 2013 3:23 AM   in reply to kitmm
    That only your video is moving and not the overlays concludes that there a differce in the source material and the sequence settings you're editing in.
    Tripple check your source material and your sequence settings. What I see in your clip is a framerate problem.
    That you wanna invest in FCP is a choice only you can make. Apple is going down at the moment, harder then they did in the 90s, only now Steve isn't coming back...
    Feb 6, 2013 11:51 AM   in reply to kitmm
    You don't.  You cerate a new sequence properly matching your media, then copy/paste the clips into it.  (You may have to make some adjustments at the edit points.)
