Does anyone have the Country codes that iPhone/iPad understands
Jan 16, 2013 7:01 AM
Tags: #as3 #iphone #ipad #locale #country_code
I'm Locale,izing my app - and suddenly bump into the problem that on the iPhone and iPad plaforms, and Mac for that matter - Apple use slightly different sets of the ISO standards. Or at least their own interpretations of them.
https://developer.apple.com/library/mac/#documentation/MacOSX/Conceptu al/BPInternational/Articles/LanguageDesignations.html
Now if I go ahead and use the Strings option in CS6 Flash Pro, it fundamentally has the basic for example 'en' and if you want the versions of 'en-US' or 'en-GB' or 'en-AU' ... you have to add them in the custom field. There is also the Chinese variants, detailed in the llink above and no doubt many others.
eg;
zh-Hans
Chinese in the simplified script.
zh-Hant
Chinese in the traditional script.
So what would be really handy, is a list of the actual contry codes returned from an iPhone4 and 5 - yes, they are different apparently, and the various iPad models.
Does anyone have such a list that they have generated? of where it can be found. I've trawled all over apple and the web and the variants are in their thousands ...
thanks
    Jan 16, 2013 8:44 AM   in reply to rachalmers
    The 2-letter 639-1 column is what it should be following:
    http://en.wikipedia.org/wiki/List_of_ISO_639-1_codes
    Jan 18, 2013 6:16 AM   in reply to rachalmers
    In your "Can't do this" example you spelled it "myTxt" while the static var is "my_txt" so you'd need to correct that.
    If you're assigning this outside the class you will need to specify the class to access the data.
    e.g.
    package
         public class SomeClass
              public static var myStr:String = "Hello World";
              // access even in the same class
              trace(SomeClass.myStr);
    // assign outside of class (do not instantiate)
    myBtn.label = SomeClass.myStr;
    If you want to set it you should use a proper setter with validation inside SomeClass:
    public static function SetMyStr(str:String):void
         // sent null, disregard
         if (!str) { return; }
         // didn't send null, set myStr
         SomeClass.myStr = str;
    Used:
    // only static members can use other statics
    SomeClass.SetMyStr("A new string");
    Jan 18, 2013 12:22 PM   in reply to rachalmers
    Doesn't matter how long any of us have been at it, a little trial and error happens every single project . Glad you got it working. You're welcome and good luck!
    Jan 20, 2013 8:25 AM   in reply to rachalmers
    I don`t understand why you don`write sth like
    function localeCallback(success:Boolean):void {
    tiAddress.text = Locale.loadString("IDS_002");
    btnGPS.label = Locale.loadString("IDS_007");
    Also: If you mark a thread prematurely as correct, it is better to start a new one and link the related threads in the header or sth.
    Your chance of getting advice would inrease.
