Dynamic Link Production Premium CS5.5 error
Jan 16, 2013 9:48 AM
Tags: #dynamic_link #premiere #cs5.5 #production_premium #ae
I have Adobe Production Premium CS5.5. I am trying to use dynamic link to send clips from Premiere to AE.  I have never had a problem with this before, however today I am getting the error: "Using Adobe Dynamic Link with Adobe After Effects requires Adobe Production Premium". What is causing this, and how to I get it working again?
    Jan 16, 2013 10:01 AM   in reply to tcbay
    Some saved Dynamic Link Problem discussions
    http://forums.adobe.com/thread/936216
    http://forums.adobe.com/thread/938108
    http://forums.adobe.com/thread/938549
    Also, it MAY be that something has gone wrong with your installation that is causing your programs to not "see" each other... a reinstall MAY fix this
    Jan 16, 2013 10:08 AM   in reply to John T Smith
    FYI, I find dynamic link in CS6 more stable.
    Jan 16, 2013 10:39 AM   in reply to tcbay
    Try the following steps:
    1. Clean your Media Cache Database (do not hesitate to locate Media Cache Database folders in your disk and delete all the files manually)
    2. Deactivate and then reactivate either PrPro or both PrPro and AE.
    Jan 25, 2013 9:09 AM   in reply to tcbay
    Did you try the second step?
    And what is your disk setup, by the way?
    Jan 25, 2013 9:40 AM   in reply to tcbay
    1. You can deactivate your application without removing serial number. Choose 'Suspend Activation'. Then just restart either PrPro or AE.
    2. How many drives have you got installed? How are they configured? Do you use external or net/shared drives? etc.
    Jan 25, 2013 10:24 AM   in reply to tcbay
    Connection errors may cause your issue.
    Try storing project files on your C: drive while media files - on the external drive.
    For the long run try to convince IT department or whoever responsible for taking decision to improve your rig.
    Jan 25, 2013 11:35 AM   in reply to tcbay
    For generic guidelines for disk setup check the link in my comment above.
    Also have a look at all Harm Millaard's articles:
    1. What PC to build?
    2. Storage rules for an editing rig
    3. To RAID or not to RAID
    etc.
