Photoshop CS6 selection, shape, and text is causing colored artifacts on screen
Jan 16, 2013 2:02 PM
Tags: #bug #colors #selection_tool #photoshop_cs6 #macbook_pro_with_retina
The Photoshop CS6 (13.0.4) selection, text, and shape tool causes colored artifacts on screen. I'm running on a retina Macbook Pro updated to the latest ML release. I have disabled GPU acceleration. I have also tried starting Photoshop with no plugins but this does not help.
I have created a video which shows the phenomena
http://www.youtube.com/watch?v=VG5ayC3WmKA
    Jan 16, 2013 2:42 PM   in reply to jklsfjasiofds
    If you've disabled the GPU and restarted Photoshop, and still have artifacts -- then you may have a very serious video card or RAM problem in your system.
    Your video shows a GPU or video driver problem.
    Have you updated your video card driver from the GPU maker's website?
    Jan 16, 2013 4:04 PM   in reply to jklsfjasiofds
    Hmm, it's still a video driver problem (and 10.8 has a bunch) - but if enabling the GPU works, then stick with that.
  • Noel Carboni
    Dec 23, 2006
    Jan 22, 2013 9:57 AM   in reply to jklsfjasiofds
    VERY interesting effect!
    Thanks for the follow-up.  That's the first I've seen/heard that a color profile could cause such strange problems!
    If you're willing to try something, could you please try this:
    Reinstate the bad profile and see if the problem comes back with the GPU enabled, but using the "Basic" setting in the Advanced GPU Options.  You'll have to restart Photoshop after making the change to the setting and before testing.
    I ask because with GPU off or GPU on and in Basic mode, color-management is done in the CPU, while in "Normal" or "Advanced" GPU modes the color-management is done in the GPU.
    If it's difficult to reproduce the original problem don't bother, I'm just curious.
    There are several known problems with the color-management logic in the GPU, but this is the first I'd heard of one in the CPU.
    -Noel
    Jan 22, 2013 11:40 AM   in reply to jklsfjasiofds
    I have the same problem
