Hello, I am trying to turn text into a wood carving on a tree and am having no luck with tuturials.
Try using transparent text. 1. Select the text tool and type on top of your tree image. 2. Then click the hand tool to deselect the text tool. 3. Make sure your text layer is selected (highlighted) in the layers pallet and on the menu click: Layer >> Layer Style >> Style Settings 4. Check the stroke box and choose a color and size (something between 1 and 5 normally works best) then click OK. 5. Using the dropdown menu at the top of the layers pallet change the blend mode from Normal to Multiply; then save.
I do not have a picture of tree bark, so I used brick for demonstration
Here's another tutorial of the Displacement Map that hatstead mentioned.
http://forums.adobe.com/thread/924420
I used it to create this example:
North America
Asia Pacific
