ahainshinsh
Photoshop CS6 'threshold' issue in the actions.
Jan 18, 2013 6:02 AM
after 13.02, the 'threshold' cannot be executed in the actions.
  • Noel Carboni
    Dec 23, 2006
    Jan 18, 2013 6:04 AM   in reply to ahainshinsh
    Have you tried 13.0.4?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 22, 2013 9:50 AM   in reply to ahainshinsh
    Perhaps you ought to describe what it's doing (wrong) for you in some detail.
    I'm able to use Image - Adjust - Threshold, recorded in an action, no problem.  Unfortunately I have only access to 13.0.1 because I have a perpetual license.  Is it something new you've seen happen only in recent updates?
    -Noel
    Jan 23, 2013 11:14 AM   in reply to Noel Carboni
    I'm having an issue too in 13.0.4 with Threshold as an action.
    If I add a Threshold Adjustment Layer manually in the Layers Tab it will pop up in the Properties Tab and will work as expected.
    If I add a Threshold Adjustment Layer in the Action Tab as a new action and toggle dialog on, the action will run, the dialog will pop up in a separate box (as opposed to the Properties Tab), but if you drag the slider to the left, add a sample color point (shift click for #1) and move the slider right (with the intention of adding another sample point #2, the original point #1 will often disappear.  In previous versions, the #1 point would persist while dragging the slider.
    Mar 21, 2013 9:24 AM   in reply to More Bacon
    i'm having the exact same problem. have you found a solution yet? running 13.1.2 x64
    really need to figure this out as it presents a majour detour in my everyday workflow.
