• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
problem with arrays
Participant ,
Jan 18, 2013 Jan 18, 2013
hi how are you guys ?  i hope you all fine ..
i have little problem with the arrays contents ..
the problem is , when i try to trace the array items it shows the arrays items as objects like this
[object Object],[object Object],[object Object]
here is the source code (i lighted the trace message and the arrays )
package {
import flash.display.MovieClip;
   import flash.events.MouseEvent
   import flash.events.Event;
public class MAIN  extends MovieClip {
  var additemsvar:String
  var addpricevar:int
  var removeitemvar:int
  var itemsnp:Array = new Array (1000000)
  var za:int = 0
  public function MAIN () {
    addbutton.addEventListener(MouseEvent.CLICK ,addbutton1)
    removebutton.addEventListener(MouseEvent.CLICK ,removebutton1)
    addEventListener(Event.ENTER_FRAME , onEnterFrame)
  public function onEnterFrame (event:Event){
   if(listbox1.selectedIndex != -1){
   itemname11.text = String({label:listbox1.getItemAt(listbox1.selectedIndex)})
  public function addbutton1 (event:MouseEvent){
   additemsvar = additems.text
   addpricevar = int (addprice.text)
   listbox1.addItem ({label:itemsnp[za]})
   listbox2.addItem ({label:itemsnp[za]})
   itemsnp.push({additemsvar:addpricevar});
   za += 1
   trace (itemsnp.toString())
  public function removebutton1 (event:MouseEvent){
   trace (listbox1.selectedIndex)
   listbox1.removeItemAt(listbox1.selectedIndex)
thank you
TOPICS
ActionScript
Views
1.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 18, 2013 Jan 18, 2013
var additemsvar:String = "whatever";
1:  itemsnp.push({additemsvar:addpricevar});
itemsnp elements are objects, not primitives like strings or numbers.  trace(itemsnp) is expected to show [object Object] itemsnp.length number of times.
2.  itemsnp.push(additemsvar);
itemsnp elements are strings.  trace(itemsnp) is expected to show each string element (eg, "whatever").
Votes
Translate
Translate
Community Expert ,
call traceItemsnpF to trace that:
function traceItemsnpF(a:Array):void{
for(var i:int=0;i<a.length;i++){
for(var s:string in a){
trace(s,a);
Votes
Translate
Translate
Report
Report
Participant ,
Votes
Translate
Translate
Report
Report
LEGEND ,
Looks like you don't have a problem with Arrays, but with objects!
The code kglad gave you should be used to trace your content so instead of
trace(itemsnp)
use
traceItemsnpF(itemsnp)
Votes
Translate
Translate
Report
Report
Participant ,
ohh , but i realy dont want to fix the problem before knowing why is that happen...
you know, if i change the red lines to
i will get the array items , but only one array not multi array like
and iam sure the problem from  these 2 bracers {}  ,, and i realy dont know why
so iam asking
1- why these 2 bracers because i have book in as2 and the book doesn,t use them.
2- why the message displays the objects instead the items .
sorry my english is bad but i hope you can understand me
thank you for your replay
Votes
Translate
Translate
Report
Report
Community Expert ,
your array (itemsnp) contains objects (or associative arrays).  when you use trace(itemsnp), flash will trace the arrays elements.  each element is an object (=associative array) and flash is tracing that accurately.
if you want to trace the objects contents, use the code i showed.
Votes
Translate
Translate
Report
Report
Participant ,
ohh , but it works with 1 array like this
why is that? i mean that i can see the items in this way not the objects
Votes
Translate
Translate
Report
Report
Community Expert ,
because additemsvar is a string, not an object.
Votes
Translate
Translate
Report
Report
Participant ,
but
additemsvar and addpricevar are also strings variables
sorry because i asked you a lot but realy this thing confuse me
thank you
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Participant ,
Jan 19, 2013 Jan 19, 2013
ohh ok
thank you mr.kglad
sorry because i lated in the replay
Votes
Translate
Translate
Report
Report
Participant ,
ohh sorry
look this the whole code
package {
  var addpricevar:int
  var za:int = 0
   za += 1
for(var s:String in a){
trace(s,a);
and the result
additemsvar 0
additemsvar 0
additemsvar 0
sorry but maybe i set the function in wrong place
Votes
Translate
Translate
Report
Report
Community Expert ,
check your additemsvar and addpricevar values if the trace output is unexpected.
Votes
Translate
Translate
Report
Report
Participant ,
Jan 20, 2013 Jan 20, 2013
still .. thank you anyway
i will try to do that in another way
thank you again for your help
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
you're welcome.
Votes
Translate
Translate
Report
Report
