When I click once on a tool to choose it, the tool's options (ex. the 3 options of the lasso) stay displayed so that I have to re-click (anywhere) before I can use it. This by opposition to the normal behavior of PS that is when you click on a tool it is choosen and you can use it right away. I must have change a preference but I can't find wich.
Photoshop CS3 extended (10.0) on Mac
There's no preference I know of that causes that behavior.
It's possible the Photoshop preferences in general have become corrupted, though I'll be darned if I can imagine how that should cause this kind of UI problem. A kind of catch-all suggestion is to reset preferences to defaults by pressing and holding Control - Shift - Alt (or Command - Shift - Option) immediately upon cold-starting Photoshop. But that comes with some downsides - you have to re-setup all your preferences.
Did you notice this change coincident with system updates, installation of a new driver, etc.?
-Noel
Noel and conroy: normal behavior when I click+hold the mouse : I can choose a variation of that tool, but still, the flyout window of multiple tools wont disapear until I click somewhere else. I did the preferences thing but no change.
I use keyboard to choose the most used tools but not always, hence my annoying problem (I should say frustrating, since I've been using PS for 20 years+). Aint no preferences/options for the tool palette?
For me, if I click and hold the left mouse button, the alternate tool choices appear. If I drag over to one of them, then let up the mouse button, that tool is selected and the alternate choices disappear immediately.
Conroy, is what plotteaterre describes typical Mac behavior, or does your system behave as I describe here?
-Noel
-Noel
Both behaviours happen on my Mac.
Your holding down, dragging over then releasing does work correctly in Ps CS5.1 and CS6 on my Mac.
However, a quick click on a Ps (CS5.1 and CS6) toolbar button, to simply select the tool, causes the flyout to appear when it shouldn't. Very infrequentlyy, a flyout correctly doesn't appear.
For about half the flyouts, the flyout can be ignored, though, and it disappears as soon as I start using the tool. Others do require the extra initial click before the tool becomes operational, as described by plotteaterre (and others, if i recall correctly).
Other Adobe apps that I use or have trialled do not misbehave in that way. A quick click always correctly produces no flyout in them.
Interesting. Thanks for detailing that.
Under no circumstances do I seem to be able to cause the flyout to occur on a quick click with the left mouse button. Click and hold with the left button or a quick click with the right mouse button aways results in a flyout.
Intermittency (or worse, as described by plotteaterre) would surely irritate me.
-Noel
You might like to try holding down the the Shift key and then repeatedly clicking the Keyboard Shortcut key for the tool in question ("B" for a Brush for example) to cycle through the different tools in the group.
I find this far quicker than selecting from the tool pop-outs and you very quickly learn how many clicks you need to get from one particular tool to the one which you want to use.
North America
Asia Pacific
