Once again, a new update, additional problems. I've removed all of the files from the data cache and described in earlier posts. Once I click a folder, now the contents wont create previews.
The little wheel in the bottom left just keeps spinning, spinning says 13 items, (92 thumbnail extraction, 1 preview extraction). And keeps spinning, spinning.
So then, after not being able to see my previews, I attempt to quit Bridge. Can't do that either. I have to "Force Quit" Bridge, only to come back to the same problem.
THIS is the quality you should expect from purchasing the CS Cloud monthly service! Every new update I will now not install, because most, not all, but most, create problems that weren't there orignially.
Thanks Adobe! My workflow has again come to a halt all around your products.....
Since you mention 'Force Quit' I assume you are on a Mac. Don't know if you have 10.8 installed but using 10.7.5 I have had no trouble whatsoever with updating from the cloud using the Adobe updater.
Also run check and repair permissions on a regular base might be of help for you.
Can you confirm your system version as well as what computer and amount of RAM, Graphic Card (VRAM) and free space left on your HD?
Thank you Gentlemen for your assistance. Yes, on a mac. 10.8.2 OSX. 2.7 GHz i5 with 786.41GB free and 16GB RAM.
I've checked and repaired permissions, repaired disks,
Command, Option, p , and r 3 times for the RAM. Not sure what the issue may be. I've also lost the ability to search for any files within finder, but thats another problem for another day.
Bridge is starting to be able to shut down after doing all of the above. I'll keep an eye out.
Steve
North America
Asia Pacific
