Problems converting FILETIME date/time into MM/DD/YYYY format...
Jan 18, 2013 12:30 PM
Tags: #coldfusion #datetime #filetime #utc
Has anyone successfully converted a FILETIME date/time value into a MM/DD/YYYY format using ColdFusion? I am failing drastically, and it seems like an easy conversion.
FILETIME format (details: http://msdn.microsoft.com/en-us/library/windows/desktop/ms724284(v=vs. 85).aspx) is a 64-bit value representing the number of 100-nanosecond intervals since January 1, 1601 (UTC).
A database I'm working with has such values, and I want to display them in a user-friendly date format within my application.
For example, one record is:
13003368600
The above number represents the following date and time:
1/22/2013 @ 2:50 PM
Sadly I know this only because the FILETIME value gets written to the database by a third-party application, and within that application I specify it in the MM/DD/YYYY format.
Can anyone offer me some guidance, or better yet has anyone accomplished this already and want to share code?
    Jan 19, 2013 11:39 AM   in reply to Adobe Forums User
    Do it step by step.
    First - divide by something to convert the filetime to seconds.
    Next - do a dateadd to 1601-01-01
    Finally, format the date.
    Note - I did a quick google search and could not find the minimum allowed date in cf.  If it's later than 1601-01-01, it's just a couple of extra steps.
    Dec 20, 2013 7:34 AM   in reply to Adobe Forums User
    I did this, on cf9/linux, and it seemed to do the trick:
    <cfscript>
    Long = createObject("java","java.lang.Long");
    Date = createObject("java","java.util.Date");
    fileTimeToEpoch =
    // take pwdLastSet From Active Directory, it's in filetime
    pwdLastSet = JavaCast("long", Long.parseLong("130292682204519505"));
    // take filetime and turn it into epoch/java - 1970/1/1
    // http://www.silisoftware.com/tools/date.php - converted: jan 1, 1970 00:00 -00
    javaTime = JavaCast("long", pwdLastSet - 116444736000000000);
    // convert to milliseconds
    javaTime = JavaCast("long", javaTime / 10000);
    today = JavaCast("string", Date.init(javaTime));
    </cfscript>
    <cfdump var="#pwdLastSet#">
    <cfdump var="#javatime#">
    <cfdump var="#today#">
