I have a PDF that was tradionally printed and filled out by hand, and am trying to convert to an e-version.
Everything is working great but I can't figure out how to make this one thing work. For example I have a section like this:
More Info: _______________
_________________________
How can I make it so when one starts typing in the "More Info" section, their response continues from the 1st line to the 2nd, to the 3rd, etc.?
Set the font size to anything but Auto.
You can set a text field to be multi-line and tick off the option to scroll
long text to have it automatically wrap, but you'll have a problem with the
first partial line, since form fields can only be rectangular. Another
problem might be the lines themselves, since you'll have to use a font size
that will fit them exactly, or it will look odd. I would suggest getting
rid of those lines altogether. They are not needed when filling in the form
electronically. It's a relic from printed out forms where people had to
hand-write their answers.
Thanks for the reply.
I'm aware of the actual "multi-line" option, and can make the rectangular word-wrap boxes.
The problem is linking the different text-field areas together.
I had planned on just removing the lines altogether for the reasons you've listed, but I'm being asked to keep them - though it sounds like it isn't going to work at all.
If you set it as multi-line you only need a single field, instead of
messing around with linking multiple text fields, which never works quite
right.
Yeah, but then I can't continue it below the "More Info:" text on the 2nd line 😕
Why not? Just start it from under the text, or to its right.
That's what I did recently. I was working on a scanned PDF and ended up redacting out the first line and nobody seemed to care.
How do you make it so that with these multi-line text fields scroll when the amount of writing in them gets too large, as opposed to just shrinking the text?
Thanks!
Great. Thanks so much
