jsgjshjs
Problem with switching between two flv streaming videos
Jan 18, 2013 12:48 PM
Hi! I´m going nuts!!! I have 2 flv streaming videos in the timeline. The flv playback containers are in diferent frames that you can acces with two buttons. Once I switch from the first video to the second.. when I return to the first one it won´t show up (it goes to the frame I told but video doesn´t charge) and from that position can´t go to the second. (It works ok locally).
This is the page: www.spyltd.com.ar   you have to go to MEDIA button.
Thank you very mucho for your help and excuse my english!
  • kglad
    Jul 21, 2002
    Jan 18, 2013 1:17 PM   in reply to jsgjshjs
    DiiaSkate.flv looks corrupted.   re-upload.  check its file size to make sure it's entirely uploaded.
    i don't see a 2nd flv.
  • kglad
    Jul 21, 2002
    Jan 18, 2013 4:33 PM   in reply to jsgjshjs
    append a random variable to both flv's name so the aborted file is not retrieved from the users cache.  eg,
    whatever_pb.source="diiaSkate.flv?nocache="+Math.random();
  • kglad
    Jul 21, 2002
    Jan 18, 2013 8:04 PM   in reply to jsgjshjs
    then paste the string i showed into the properties panel's source listing after selecting your playback component.
  • kglad
    Jul 21, 2002
    Jan 19, 2013 5:10 PM   in reply to jsgjshjs
    leave it as2.
    paste that string into your components contentPath property, the same place you asssigned which flv to play.
  • kglad
    Jul 21, 2002
    Jan 20, 2013 3:52 PM   in reply to jsgjshjs
    click on your flv playback component that is on-stage (to select it).  in the properties panel assign an instance name (eg, flv_pb).  then in the actions panel attached to the frame (not the component) that contains your component, paste:
    flv_pb.contentPath="diiaSkate.flv?nocache="+Math.random();
  • kglad
    Jul 21, 2002
    Jan 21, 2013 7:26 AM   in reply to jsgjshjs
    remove that from whereever it is located (probably in the properties panel after selecting your component).  there should be no string in the contentPath property in your component's property panel.
  • kglad
    Jul 21, 2002
    Jan 21, 2013 10:01 AM   in reply to jsgjshjs
    at no time have i ever suggested using the code that's mentioned in the error message.  you have that elsewhere or you failed to copy and paste the code i suggested.
  • kglad
    Jul 21, 2002
    Jan 21, 2013 12:30 PM   in reply to jsgjshjs
    you're welcome.
