Hello,
I'm having an issue with only one of three media files in my Premiere Pro CS6 project.
When I try to preview this one video file in the Source Monitor, it shows only a white screen, and I can only move the playhead to the beginning and end of the file. I then plopped the clip into the sequence to see if rendering it would give me better luck in the Program Monitor, yet to no avail. The file supposedly successfully rendered, yet when I open the subsequently created "Preview" file in VLC, the entire clip is completely white for its entire duration. (I think it's interesting to note that VLC plays the source file correctly, and that this footage has been successfully used in a separate project in Final Cut after converted to ProRes with Compressor.)
I've opened the file with GSpot to make sure I had the Codec installed, yet GSpot doesn't list any Codec information for this file. It only lists Container information.
(Screen shot of GSpot with white-screen issue in the background)
My Video Card drivers are up to date, taken directly from the chipset's manufacturer's website.
Codec: (See post below for Media Info dump)
Premiere Pro version 6.0.3 (001 (MC: 264587)), installed in English.
Sequence Settings: DVCPROHD 1080i50 default settings (framerate changed to 50FPS)
Windows 7 x64 Service Pack 1, English, 1440x900 32bit Color
Pentium(R) Dual-Core CPU T4200 @ 2.00 GHz
2GB RAM
Mobile Intel(R) 4 Series Express Chipset Family, Driver version 8.15.10.2869
53.2GB of free space on the SSD all of the media files, the operating system, the Adobe Premiere installation, and scratch disk is located.
I'm unsure of the camera used to record this footage.
Thanks for reading my post, and let me know if you need any more information. ![]()
General
Complete name : C:\Video Workspace\Source Media\VSB 01 Stand Bühnenkamera VORNE.mpeg
Format : MPEG-TS
Commercial name : HDV 1080i
File size : 11.4 GiB
Duration : 1h 0mn
Start time : UTC 2011-10-16 17:36:49
End time : UTC 2011-10-16 18:37:17
Overall bit rate mode : Constant
Overall bit rate : 27.0 Mbps
Maximum Overall bit rate : 33.0 Mbps
Encoded date : UTC 2011-10-16 17:36:49
Video
Menu ID : 100 (0x64)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High 1440
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Codec ID : 2
Duration : 1h 0mn
Bit rate : 25.3 Mbps
Maximum bit rate : 25.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.650
Stream size : 10.7 GiB (94%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 1h 0mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -40ms
Stream size : 166 MiB (1%)
Menu
List : 2064 (0x810) (MPEG Video) / 2068 (0x814) (MPEG Audio) / 2069 (0x815) () / 2065 (0x811) ()
Nice try, but no luck.
It's also interesting to note that sometimes when I open the same project, it shows the first frame of the clip instead of a white screen. Though the problem persists, as I cannot edit or even view any other part of the clip. Rendering in this circumstance leaves a preview file with the first frame playing throughout the clip's entire duration.
Since I have a deadline on this project, I've reverted back to Premiere CS5.5. This configuration seems to work perfectly fine, though I am willing to try any suggestions to hopefully find a solution for anyone else with a similar issue.
North America
Asia Pacific
