Hi, hope the Q is in the right place.
I've been using DW on and off for years but this issues a real nuisance.
I can preview anything but framesets in IE9. I'm using DW Mx2004.
IE throws up "Internet Explorer cannot display the webpage".
It's showing D:\Sites\HKAB\TMPasu8jgvfk5.htm in the top bar so attempting to use a temporary file.
Got to be something simple, looked at everything that might cause this, but no luck so far.
Help please.
Just getting a blank page (Firefox). However mouse over picks if the frame ID.
Looks like the systems trying to get there but there must be a small tweek to do or undo to get it functioning properly.
IE9 shows a split screen, as in replicating the frameset, with "Internet Explorer cannot display the webpage" message in each
The address is www.hkab.co.uk
My daughter put this together for me and I'm slowly modifying it.
I think this is the frameset code
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Frameset//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-frameset.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Harrogate Kitchens and Bathrooms idx</title>
</head>
<frameset rows="220,*" cols="*" framespacing="0" frameborder="no" border="0">
<frame src="/indextop.html" name="top_Frame" scrolling="No" noresize="noresize" id="top_Frame" title="top_Frame" />
<frame src="/indexmid.html" name="main_Frame" id="main_Frame" title="main_Frame" />
</frameset>
<noframes><body>
</body>
</noframes></html>
Thanks -
Frames, as a layout method is so dysfunctional, I have to admit, that I am not sure how to code them.
This explains why: http://www.apptools.com/rants/framesevil.php
I think you will be thrilled if you utilize Server Side Includes which are easy to learn, and so easy to maintain.
Meanwhile repair these errors:
Thank you for the information.
The link you forwarded explains a lot.
As an infrequent user of DW I have in the past used tables. I was trying to unpick these frames and got totally baffled by them. From on line comments, I'm not the only one.
Following the link, I'm going to convert these frames to tables, which to me are considerably more logical.
I ave it in tables but not quite as I like.
Had another go at frames and got good results .................... then
I'm beginning to think this is all down to the potentially strange behaviour of frames.
Got it all cracked and uploaded, previewed once, looked fine, then on returning to the online site again it dissapeared giving "page not found" again.
Rubbish. No changes in files or code.
Is there some reason it won't let you view twice? This would also explain why I kept losing it in preview.
Any suggestions?
Frames were popular in the 1990s but not anymore. Nobody uses them. Mobile devices don't handle framed sites well. And more importantly, the W3C removed support for frames from HTML5 web standards.
http://www.tutorialspoint.com/html5/html5_deprecated_tags.htm
Eventually, browser developers will likely drop support for them, too. So don't use frames. You don't need them or the headaches they create for you and your site visitors.
I urge you to get up to speed with Cascading Style Sheets (CSS). Table based layouts are inefficient and labor intensive, especially if you later decide to make global changes to the appearance of your site. With CSS, you can re-style your entire site with a few lines of code. With tables, you must tediously re-code every page.
To illustrate the power of CSS, go to CSS Zen Garden. Each page contains identical content. Only the style sheets are different. You can't do this with tables.
HTML & CSS Tutorials:
Dreamweaver CSS Starter Pages:
http://www.adobe.com/devnet/dreamweaver/articles/introducing_new_css_l ayouts.html
Nancy O.
North America
Asia Pacific
