Trouble making cuts
Jan 19, 2013 8:07 AM
Tags: #sequence #mxf #razor #cutting
When i use blade, it is making a different cut on video and audio, and they are still linked.  And sometimes I can't make a cut at all.  Any help is very much appreciated!
    Jan 19, 2013 8:25 AM   in reply to Johnlavall
    First, zoom in a bit on the timeline so you can see a little better, then post a screen shot of what you see when you cut so we can better understand the exact question.
    Jan 19, 2013 10:21 AM   in reply to Johnlavall
    Make sure the sequence settings match your footage.  I've seen similar behavior when the frame rates of media and sequence do not match.
    Jan 19, 2013 12:48 PM   in reply to Johnlavall
    Dont use the "blade". ( Razor Tool).  (A crude and blunt editing instrument despite its name)
    Position the playhead and use the Keyboard Short Cut for "Add Edit".  CTRL-K or SHift-CTRL-K
    No need to zoom in to use this tool. The Program Monitor is your friend.
    Ensure your tracks are targetted.
    Jan 21, 2013 9:44 AM   in reply to Johnlavall
    Sometimes I noticed that if you CTRL-K, it may not cut it.  You need to click on the playhead first.
    Jan 21, 2013 11:45 AM   in reply to paddyz123
    No.
    Ensure the track is "targetted" and it will cut every time.
    Use Shift=CTRL-K if you want to cut hrough all tracks.
