[URGENT HELP NEEDED] Premiere Pro CS6 failed rendering
Jan 19, 2013 10:01 AM
Tags: #premiere_pro #rendering #failed #cs6
Hello!
I`ll try to make this quick because I need help asap. I`ve been starting to make YouTube gaming videos 3 weeks ago and my channel is growing up pretty fast. I promised I would make a video everyday but it`s been a full week since I couldn`t upload because I was busy and when I tried to render it failed.
Anyway here`s how it goes.I`ve recorded with fraps some gameplay footage with the resolution of 1360x706. One of my friends reccommanded me Adobe Premiere Pro for editing so I`m using the trial version of CS6. I create a new project and choose a format of 720 25 (cant really remember the exact name). I then import my recorded files and when I place them in the sequence it tells me the resolution is different and asks me if I want to change the sequence settings according to the files. Usually, I ignore it and when I export the Media I just tick the option: "Scale to Fill" and that usually works just fine, quality HD on YT...
But this week it has driven me crazy, I really don`t want to explain how much stress and dissapointment this has caused to me because I think I`ll end up raging...I`ll just tell you I`ve been trying for a couple of days more than 7 time to render the project(each time it takes about an hour and a bit more, so let`s just call it 7 hours wasted). The problem actually is that when I check the output file after exporting the media, the file size is ONLY 24 bytes!!! Other times the file size gets to like half of the one that should be or less, but mainly the render even so takes up a normal length of time of processing but in the end the file is only 24 bytes..Thing is I don`t encounter any error whatsoever...
I really need some urgent help!
Thanks!
    Jan 19, 2013 10:23 AM   in reply to GameLordozaur
    1st, some FRAPS information
    These are for Premiere Elements, but may help with PPro
    Fraps & Elements http://forums.adobe.com/thread/871095
    -and more Elements http://forums.adobe.com/thread/943772
    -and yet more Elements http://forums.adobe.com/thread/967201
    2nd, it is REALLY better to have your project sequence match your video
    Please NOTE that the PPro CS6 screen may look a bit different (I use CS5)
    For CS5 and later, the easy way to insure that your video and your project match
    See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
    -and a FAQ on sequence setting http://forums.adobe.com/message/3804341
    Jan 19, 2013 10:45 AM   in reply to GameLordozaur
    Any time you try to force a round peg into a square hole... force a video into an incorrect project/sequence... you run the risk of causing problems
    Edit in a project/sequence that is correct for your video, and you may/should have fewer problems
    Jan 19, 2013 2:10 PM   in reply to GameLordozaur
    Settle down mate.  You will wake the baby!
    You are working with non standard video so you need to get your settings sorted.
    How about telling us everything about the  fraps source files, the sequence settings and your export settings.
    Knowing a bit about your computer and the way it is set up will help as well.
    Jan 19, 2013 2:34 PM   in reply to GameLordozaur
