I have about 10 files (.mpg converted from VHS to Digital). Each file is ~4 to 6GB in size. I'd like to pull them into Premiere Elements 8.0, edit and create menus. When I started I tested one project to burn I noticed that roughly 2 hrs of video will consume the entire BD disk (25GB). Could this be an issue with the project settings and/or the output settings?
I'm using HDV 720p, frame size 1280 x 720, 48khz for project settings.
Using H.264 440x1080i NSC Dobly for the preset to burn to BD.
From reading some threads, it may have been better to have converted these VHS's to avi vs mpg. Any advice at this point? As always, feedback is greatly appreciated.
You vhs files are probably SD (standard definition) 720x480.
Putting then in a HD project (720P) and exporting yet to different HD resolution will not work well.
You can burn SD to a BD but you will have to leave it SD.
Uprezzing SD to HD without the proper tools will not look good in Elements.
As Ann says, we need to know more about those fils. MPEGs can be practically anything!
Who converted this VHS video to MPEG? If you did it yourself, you're going to have problems, since you likely used a capture card or USB-connected device, which will not produce files that will give you a good quality edited video. Particularly if these are standard definition MPEGs, blowing them out to a BluRay disc is going to make them look truly awful.
Open one of MPEGS in a program like G Spot or Media Info and list its resolution, frame rate and, above all, its codec.
Ann/Steve,
This capture was done via Dazzle. The VHS tapes are SD (720x480). I have about 15 Hi8 tapes after I finish the VHS tapes. Did some additional research and appears that I can still use Dazzle and abandon the Pinnacle Studio and use instead "VirtualDub" to get an avi file that I believe is best to preserve quality and allow Premiere Elements to efficiently edit and create a digital file for burning. Will this work? To be clear on my objective, I want to take many VHS tapes (~30), convert to digital format, edit and burn to BD disks. I'd like to maintain quality, but my hope was to ahve ~ 6 hrs of play per BD. Thanks in advance of your reply on this topic........... still learning
I'm running a Dell XPS 435MT, x64, i7 quad core, 6GB RAM, ATI Radeon HD 4800 Series, 750GB HardDrive, two 1TB external HD's
here is the info on one of the files:
Format : MPEG-PS
File size : 957 MiB
Duration : 18mn 18s
Overall bit rate mode : Variable
Overall bit rate : 7 306 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Duration : 18mn 18s
Bit rate mode : Variable
Bit rate : 6 937 Kbps
Maximum bit rate : 8 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.670
Stream size : 908 MiB (95%)
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Mode : Joint stereo
Mode extension : Intensity Stereo + MS Stereo
Duration : 18mn 18s
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 29.3 MiB (3%)
I have not read much that was good about Dazzle
The model 55 at http://www.grassvalley.com/products/converters will create the DV AVI you need for editing... as long as your computer has a Firewire port
North America
Asia Pacific
