wild&wonderful
Using CS6 32Bit Plug in Doesn't Work?
Jan 19, 2013 10:39 AM
Plug in filter works only in 32 bit and when I open an image and click on the filter I get an error message - Memory Access Violation.  Can't get any farther.
What do I do?
If giving an explanation please assume I know nothing!
    Jan 19, 2013 11:09 AM   in reply to wild&wonderful
    What OS version?
    Have you installed all the Photoshop updates?
    What plugin?
    Most likely there is just a bug in the plugin.
  • Noel Carboni
    Dec 23, 2006
    Jan 19, 2013 5:15 PM   in reply to wild&wonderful
    (Assuming you have room) you can have both versions of Photoshop installed on your system at the same time.  They keep separate from one another.
    If an older plug-in is incompatble with the latest Photoshop, have you investigated getting a newer copy of the plug-in that IS compatible?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 19, 2013 7:26 PM   in reply to wild&wonderful
    I'd leave it at defaults to start with.  Why do you ask about RAM?  Are you seeing problems where you're led to believe there's a RAM shortage for some part of the operation?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 21, 2013 8:28 AM   in reply to wild&wonderful
    It's likely not a lack of RAM that's causing the problem, but a bug in the plug-in's implementation that's been uncovered by changes to Photoshop.  Plug-ins that closely (and correctly) follow the Photoshop SDK (software development kit) guidelines don't usually have problems, but this particular plug-in may have taken some liberties with the interface.  I have heard that plug-ins created with some older (non-Adobe) plug-in frameworks have problems similar to what you're describing.
    If you can't get a newer version  of the plug-in, then your workaround (to use an older version of Photoshop) is probably your only recourse.
    -Noel
