Photoshop Elements 11 Organizer: Full screen view of lower quality than with PSE 10 and before?!
Jan 19, 2013 12:23 PM
Tags: #organizer #low_quality #full_screen_mode #photoshop_elements_11 #pse11
Upgrading from PSE 10 to 11, I noticed that when I watch my images with the organizer in PSE 11 in full screen view mode (F11), while the images load faster, they are shown in a lower quality than in PSE 10 or any other version of PSE that I owned before. In PSE 11, after the initial viewing in full screen (in the "fit screen" mode), when I click with the mouse on an image to display the "100%" view, there is a delay and the program says "Loading...", after which the 100% view in the full screen mode appears. When I then click another time with the mouse on the image to get back to "fit screen" mode, I get an image of better quality than during the initial view!
So it seems like the program first gives a faster, but lower quality view of the image in full screen mode, and only after the user requests a 100% view, it actually loads the image with full detail, which is then preserved when going back to the "fit screen" view. This is a serious issue for me, because I also use PSE organizer to present my pictures to other people, and I don't want to show them some lower quality versions of my images, but the full quality ones, without having to first choose "100% view" and then go back to "fit screen".
How can I make the PSE 11 organizer give me a full-quality full screen image right away, as this used to be the case in PSE10 and before?
(I have both versions, PSE 11 and PSE 10, now on the same computer and tested this to confirm that the PSE 11 initial full screen view is of lower quality than the PSE 10 one. Also in PSE 10, there is practically no delay for displaying the "100%" view afterwards, indicating that the image was loaded with full detail right away.)
    Jan 24, 2013 9:55 PM   in reply to polarhki
    Hi...
    A few questions on this issue-
    What happens if you launch Full Screen View and then wait for a second or two so that the first image loads completely (in high resolution) and then start navigating using say arrow keys. Does the Loading symbol still comes?
    What format of file are you viewing in FSV and what is the average size?
    Does the same issue happen when you start FSV using the "Slideshow" button present on the bottom action panel?
    Andaleeb
    Feb 3, 2013 12:50 PM   in reply to polarhki
    polarhki has continued this discussion here:
    http://www.elementsvillage.com/forums/showthread.php?t=76799
    You can share your comments here and see if the solution in post #14 (with the hidden prefs in Elements+) may be good for you.
    Mar 21, 2013 5:00 PM   in reply to polarhki
    Just found this thread & totally agree with Polarhki - I noticed the fullscreen preview wasn't so good & was beginning to think it was my eyesight that was the problem!
    To me, being able to see my photos fullscreen in the best possible quality is the most important feature of Elements (surely the whole point of a fullscreen preview?) & I don't want to open every picture up in the editor just to see it at it's best. I only use Elements to organise my files, I use CS6 for editing them.
    Due to this latest downgrade and the fact that you can no longer open the F11 preview on a separate monitor (as you could with previous versions), I find I'm using Elements very rarely these days.
    I'm tempted to uninstall PSE11 & go back to PSE10 although I don't know if the catalogue would still work or if you can convert it back to an earlier version.
    It really annoys me when companies do this - bring out a newer version that has features missing from previous versions.
    I guess it's very unlikely Adobe will take onboard our comments - as with most large companies they'll carry on regardless, safe in the knowledge that they know what we want better than we do
    Mar 22, 2013 12:28 AM   in reply to Les_Cornwell
    You don't need to open the editor, as already mentionned several times in this thread. You only need two clicks on the image : the first one to go to 100% view, the second to get back to full window view. What is shown then is exactly what you got in previous versions (two clicks, two seconds).
    In my experience, PSE11 is much quicker than previous versions in its display even with raw files.
    There are two reasons to prefer the bicubic sharper algorithm :
    - providing a 'snappier' image in F11 used as a slideshow. That's mainly valid for showing on small displays or laptops. On my 1920x1200 24" calibrated screen, I don't really need it, but I understand that it should be offered, at least as an option.
    - Evaluating the detail quality (pixel peeping) of images. If you are serious about quality, you judge at 100% view without any downsizing and you can tell the difference between sharpening levels and detail quality. The problem is still harder when you are mostly working on raw files where you have several steps of sharpening in the ACR dialog and possibly in the editor depending on your output choice.
    Well, maybe you know better that me what I want But since we are at guesses, I think if I were Adobe, I would take that request seriously... time will tell.
    Mar 22, 2013 4:31 PM   in reply to MichelBParis
    I appreciate you can click twice to get the sharper version but it is a pain if you want to look through a set of pictures, having to press the L or R arrow key then mouse click twice.
    As to only being valid on smaller displays - I use a 20" non-widescreen Dell Ultrasharp monitor & the difference is quite noticeable.
    I just cannot see the point of making images appear less sharp on screen when surely the whole point is to view out photographs at their best?
    Mar 23, 2013 1:01 AM   in reply to Les_Cornwell
    That's a big point. Not a technical point, I would say an artistic point. We do agree that the difference in the display is the sharpening, not the detail level. So you prefer photographs to be displayed sharper to be at their best. Many film oldtimers consider that level of sharpening as an obvious defect typical of digital images. No one is right, no one is wrong. That's why I agree that there should be an option about the downsizing and sharpening method.
    It has been mentionned in this discussion that viewing photos at their best when downsized on a display implies other much more important factors :
    - screen size and resolution
    - calibration and gamut
    - angle of view (how many viewers ?, at which distance ?)
    - lighting of the viewing room...
    So, while I do agree that everyone should be able to get the 'quality' of sharpening they prefer, I strongly suggest to think about the conditions of the viewing session to optimize the output.
    I do maintain that if what you want is a organizing session for yourself to sort pictures by pixel peeping, the present PSE11 F11 view is adequate.
    If what you want is to create a kind of 'instant slideshow' for showing 'at its best' to several persons, you should prepare albums or folders with resizing and sharpening optimized to the output display so that you get better results than with PSE11... or any previous version.
    You have the choice to export your selected files or to use the 'process multiple files' feature : then I strongly recommend to test if the default export sharpening option is ok for you (it's very strong).
    For the very best results, I would use free external tools like FastStone photo resizer which offer more advanced resizing and sharpening algorithms for batch edition. That would be true even if Adobe restored the old 'bicubic sharper' solution.
    Mar 25, 2013 3:47 AM   in reply to MichelBParis
    I just like my images to be displayed, not sharper than they should be, but as sharp as they should be which is how I believe they have always been displayed in previous versions of Elements. I feel that in an attempt to make the F11 preview quicker, PSE11 creates a less sharp almost blurry image (which is more or less what Bobby from Tech Support has suggested above).
    If I want to look through a set of pictures I've just taken or show them to a friend or family member, why should I have to "prepare albums or folders with resizing and sharpening' just to show my pictures to someone or view them myself? The alternative of course is to have to double-click each photo every time or explain that "No, I do still take sharp photos, it's just that Elements makes them look blurred by default!"
    As that's the way previous versions have worked, Adobe should have left as is & given us the option to change to the new method if we want to, not just enforced it. And along with disabling dual monitor support it's instantly removed for me at least, the two most important functions.
    PS. How does one escalate an issue to Adobe staff?
    Mar 25, 2013 12:44 PM   in reply to Les_Cornwell
    Myself I will not so call upgrade from 10 just over this issue. Give us the choice for viewing?
    Mar 25, 2013 3:02 PM   in reply to seamutt33
    I certainly wont bother with any more Elements upgrades until this issue is resolved AND  dual monitor support is restored.
    Unfortunately I don't think I can revert my catalogue from PSE11 back to PSE9. If it was possible, I would go back to using PSE 9 and uninstall PSE11.
    It would be nice if when releasing an new version of Elements, Adobe told customers what features they would be removing as well as telling us about any new ones, or better still, dont remove the features in the first place!
    Shame we can't email Adobe about these omissions but I cant see how to do it - perhaps they dont want to listen
    Apr 12, 2013 10:28 AM   in reply to Les_Cornwell
    Tried to raise this issue (and removal of dual monitor support) via 'chat' today without much success; other than a 'that's how it is supposed to be response' regarding fullscreen preview and 'dual monitor setup is not reccomended'.
    I did point out that whichever way you look at it, both issues I raised worked fine with PS9 but don't with PSE11 and at least got agrrement to escalate to 2nd line support.
    I just find it so frustrating when large companies decide to change a product without informing customers and then attempt to explain the change as 'that's how the product is supposed to perform'. in other words, "We've changed it, if you don't like it tough, most people won't bother complaining".
    Time to move on from Elements and look elsewhere. What's so annoying is that even programs like Faststone viewer let you adjust how you like your images to look when you view them and that program is free! Surely as a paid for program, elements could at least give customers a choice??
    May 4, 2013 8:03 AM   in reply to Les_Cornwell
    Never heard back from 2nd line support not that I'm surprised.
    So basically, we've changed it, that's how it is now, if you don't like it, tough.
    Won't be bothering with Elements any more
    May 31, 2013 1:38 AM   in reply to polarhki
    I still haven't heard from Adobe 2nd line support and dont expect to.
    I wish I could email Adobe about this but there doesn't seem to be a facility to do so & I doubt they would take any notice either.
    I just cannot work with the organiser as it is & dont use the editor (use CS6 for editing) so think I will reinstall PSE9, update a copy of the old catalogue I had for PSE9 & just use that. I may keep the PSE11 catalogue updated too just in case a future version of Elements corrects the preview issue & reinstates dual monitor support, but I wont be buying it before installing a trial next time!
    What with making CS subscription only in future too, Adobe sure know how to get rid of customers!
    EDIT:  PSE9 now installed, catalogue updated. Much nicer - no more burred images & dual screen support again   Will be certain to try out trial version before I 'upgrade' to later version again
Bookmarked By (1)
