Help! Changes in forms in DW CS6?
Jan 19, 2013 11:06 AM
Tags: #dreamweaver #forms #cs6
I've been using an extention called HDW Form2mail for Dreamweaver for a while.  It has always been a simple way to get info from my site without a database.  But it's not working right in DWCS6.  I notice that while placing form elements in my form that the info box that use to pop up in DWCS5 no longer comes up.  You use to be able to insert labels and other options.  Is that now removed?
Anyway, when I go back and creat the form in CS5 and use Form2mail it works perfect.  But in DWSC6 it does not.
Here are examples if you have moment.
This is the one created in CS5 that works perfect:
http://bvcwebdesign.com/bvcWebDesignContact.html
This is the one that doesn't work done in DWCS6:
http://bvcdesign.com/form2.html
By the way, I contacted the maker of this extention and downloaded the latest version.
Any insight would be so appreciated!
Bernie C
    Jan 19, 2013 12:21 PM   in reply to bernwa
    Instead of the Insert menu, use the Insert Panel, click on Forms.
    Label attribute is at the bottom.
    See screenshot.
    Nancy O.
    Jan 19, 2013 1:14 PM   in reply to bernwa
    If you have a form that works, put that code in your Snippets Folder for quick insertion into other web pages. Working this way, I have little need for Form tools.
    For Cloud users, DW 12.1 update introduced a significantly re-organized Insert Menu.
    http://blogs.adobe.com/dreamweaver/2012/10/dreamweaver-creative-cloud- update-12-1-faqs.html
    If these changes adversely effect your workflow, tell Adobe about it.
    Bug Report & Feature Request Form
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Nancy O.
