BeyondtheSmile1
Removing background that is same color as subject's hair
Jan 20, 2013 9:20 PM
I have CS6. Having trouble removing a background where part of the backgrouond is almost exactly the same color as the subject's hair. I've tried the refine edge tool- I get yucky greyed areas in the one spot where the hair & the similar background color meet. I have tried to use channels, but I am not very skilled in that yet. Any suggestions would be great! Really need to figure this out!!
    Jan 20, 2013 11:32 PM   in reply to BeyondtheSmile1
    Could you please post a screenshot or part of the image to illustrate the issue?
    Jan 21, 2013 3:25 AM   in reply to BeyondtheSmile1
    You can download a plugin that was available with CS3 and for no reason Adobe removed that from CS4 and later versions. It learnt that at www.dynamicwebtraining.com.au and my instructor told me how to install the plugin but you will find details here. With this filter you can easily remove the hair. It is amazing.
  • JJMack
    Jan 9, 2006
    Jan 21, 2013 5:28 AM   in reply to BeyondtheSmile1
    In order to separate things you need to find some type of contrast between the objects. When hair  lacks contrast between its color and the background it can be very difficult.  Often it best to just zoom way in on the problem areas and paint the mask in these areas by hand.  With the subject layer the current lay and subject visible target the mask on that layer, paint with low opacity using black and white paint in overlay mode to protect the white and black mask areas only the gray areas can be painted on. Paint with black to hide the background paint with white to bring back hidden hair use many strokes low opacity overlay mode takes time and practice. If there is an area that will not change switch to gray paint normal mode and paint that area gray. The switch back to low opacity black and white paint in overlay mode.  Remenber X switches the Foreground and Background color paints.
    Jan 21, 2013 11:03 PM   in reply to BeyondtheSmile1
    Could you please post the detail that’s bothering you with the background?
    Jan 22, 2013 5:22 PM   in reply to BeyondtheSmile1
    Can you post the image with the original background?  It’s not clear where the gray is coming from.  Also can you post a full-100%-size crop of the hair area with the problem.
    Another issue is that there is significant color noise in the woman’s hair, red and green blotches.  If those are in the original then it might be good to use some noise-reduction on the color noise.  If those are just an artifact of posting the jpg to the forum then it’s not a problem.
    Jan 22, 2013 5:49 PM   in reply to ssprengel
    Yes, indeed, if you could post the original image, it would help us
    Jan 23, 2013 3:18 PM   in reply to BeyondtheSmile1
    Martin Evening has a good video tutorial on using the Refine Edge (Refine Mask) dialog. In it, there is a Decontaminate Colors control. Sometimes it works wonders... other times not so much.
    http://www.photoshopforphotographers.com/pscs5/Movies/PSCS5-hair_maski ng.mov
    Jan 23, 2013 5:34 PM   in reply to BeyondtheSmile1
    The Russell Brown masking basics is excellent.  But am getting a 404 error so maybe server down now.
    http://tv.adobe.com/watch/adobe-evangelists-russell-brown/masking-basi cs-in-photoshop-cs5/
  • Noel Carboni
    Dec 23, 2006
    Jan 23, 2013 7:14 PM   in reply to BeyondtheSmile1
    Haven't gone through this thread in any detail, but one thing to keep in mind:  The higher the quality of the photo the better results you'll get.  If Photoshop has to tiptoe around image noise and too few pixels then it can only do so much.  It would be better to work on a MUCH larger image than the one you showed above.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 23, 2013 7:27 PM   in reply to Noel Carboni
    In fact, just upsampling the image to a larger pixel count, then using the Refine Edge function immediately helps get better results.  This was downsampled again after the masking.  Literally less than 5 minutes work went into this.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 23, 2013 8:01 PM   in reply to BeyondtheSmile1
    I have Photoshop keep a log.  This is what I did in a nutshell:
    • Upsampled your small image to 1600 pixels width.
    • Quick Selection Tool to select the people, with a couple of secondary strokes (Alt key down to remove things it over-selected).
    • Refine Edge, to new layer with mask.  Painted areas of Transition with the brush.
    • Tweaked a couple of controls, notably Shift Edge to make it select a bit less hair and Increase Contrast.
    • When finished, some very minor hand touch-up to the mask.
    Here's the detailed log:
    2013-01-23 22:15:04 File  opened
    Image Size
      Image Size
       Width: 1600 pixels
       With Scale Styles
       With Constrain Proportions
       Noise: 0
    Hue/Saturation
      Hue/Saturation
       Preset Kind: Custom
       Without Colorize
       Adjustment: hue/saturation adjustment list
       Local Range: 1
       Begin Ramp: 315
       Begin Sustain: 345
       End Sustain: 15
       End Ramp: 45
       Hue: 0
       Saturation: -24
       Lightness: 0
      Select quick selection
    Quick Selection
    Quick Selection
    Quick Selection
    Quick Selection
    Quick Selection
    Refine Edge
      Refine Edge
       Radius: 0 pixels
       Contrast: 9%
       Smooth: 0
       Feather: 0 pixels
       Shift Edge: -8%
       Without Smart Radius
       Without Decontaminate Colors
       Output: New Layer with Layer Mask
      Select mask channel
       Without Make Visible
      Exchange Swatches
      Select brush
    Brush Tool
      Select layer “Background”
    New Gradient Fill Layer
      Make fill layer
       Using: fill layer
       Type: gradient
       Angle: 90°
       Type: linear
       Gradient: gradient
       Name:  “Foreground to Background”
       Form: custom stops
       Interpolation: 4096
       Colors: color stop list
       color stop
       Color: RGB color
       Red: 0
       Green: 0
       Blue: 0
       Type: user specified color
       Midpoint: 50
       color stop
       Color: RGB color
       Red: 255
       Green: 255
       Blue: 255
       Midpoint: 50
       Transparency: transparency stop list
       transparency stop
       Opacity: 100%
       Midpoint: 50
       transparency stop
       Opacity: 100%
       Midpoint: 50
      Select mask channel of layer “Background copy”
      Select brush
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    Brush Tool
    2013-01-23 22:19:21 File C:\TEMP\Masked.jpg saved
      Save
       As: JPEG
       Quality: 12
       Matte: none
       In: C:\TEMP\Masked.jpg
       1404
       With Copy
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 23, 2013 8:05 PM   in reply to BeyondtheSmile1
    DEFINITELY watch Russell Brown's "Less is More" tutorial.  I follow that technique almost to a "T".
    Here's an alternate link to that video:
    http://www.photoshop.com/tutorials/6745
    -Noel
