Spry Tabbed Panels not working in IE - any Version
Jan 20, 2013 10:18 PM
Tags: #spry #ie #panel #tabbed
On on of my pages I have a spry tabbed panel within another tabbed panel.  I have no problem with this page in Safari, Opera, Chrome, FF on my Mac.  It also works fine in FF on Windows XP, but It does not work at all in any version of IE.
I have one tabbed panel with 3 tabs and in the 2nd tab I have a tabbed panel with 6 tabs.  When I open the page in IE all tabs in the first tabbed panel are open, showing all content.  The second tabbed panel only the first tab is showing its content.  When I try to click on any of the other tabs they do not work.
Here is a link to my test page: http://www.alpinevalleyoutfitters.ca/gallery.html
Here is my spry tabbed panels css
@charset "UTF-8";
.TabbedPanels {
          overflow: hidden;
          margin: 0px;
          padding: 0px;
          clear: none;
          width: auto; /* IE Hack to force proper layout when preceded by a paragraph. (hasLayout Bug)*/
/* This is the selector for the TabGroup. The TabGroup container houses
* all of the tab buttons for each tabbed panel in the widget. This container
* does not contribute anything visually to the look of the widget for our
* default style.
* The name of the class ("TabbedPanelsTabGroup") used in this selector is not
* necessary to make the widget function. You can use any class name you
* want to style the TabGroup container.
.TabbedPanelsTabGroup {
          margin: 0px;
          padding: 0px;
/* This is the selector for the TabbedPanelsTab. This container houses
* the title for the panel. This is also the tab "button" that the user clicks
* on to activate the corresponding content panel so that it appears on top
* of the other tabbed panels contained in the widget.
* For our default style, each tab is positioned relatively 1 pixel down from
* where it wold normally render. This allows each tab to overlap the content
* panel that renders below it. Each tab is rendered with a 1 pixel bottom
* border that has a color that matches the top border of the current content
* panel. This gives the appearance that the tab is being drawn behind the
* content panel.
* The name of the class ("TabbedPanelsTab") used in this selector is not
* necessary to make the widget function. You can use any class name you want
* to style this tab container.
.TabbedPanelsTab {
          position: relative;
          top: 2px;
          float: left;
          padding: 4px 10px;
          margin: 0px 1px 0px 0px;
          background-color: transparent;
          list-style: none;
          border-left: solid 2px #452200; /*#F36F25;*/
          border-bottom: solid 2px #452200; /*#F36F25;*/
          border-top: solid 2px #452200; /*#F36F25;*/
          border-right: solid 2px #452200; /*#F36F25;*/
          border-radius:5px 5px 0px 0px;
          border-top-left-radius: 5px;
          border-top-right-radius: 5px;
          -moz-border-radius: 5px 5px 0px 0px;
          /*-moz-border-radius-topleft: 5px;
          -moz-border-radius-topright: 5px;*/
          -webkit-border-radius:5px 5px 0px 0px;
          /*-webkit-border-top-right-radius:5px;
          -webkit-border-top-left-radius:5px;*/
          -moz-user-select: none;
          -khtml-user-select: none;
          cursor: pointer;
          font-family: "Trebuchet MS", Arial, Helvetica, sans-serif;
          font-size: 100%;
          font-weight: bold;
          behavior: url(../css/PIE.htc);
/* This selector is an example of how to change the appearnce of a tab button
* container as the mouse enters it. The class "TabbedPanelsTabHover" is
* programatically added and removed from the tab element as the mouse enters
* and exits the container.
.TabbedPanelsTabHover {
          background-color: #99470F;
          border-bottom-color:#99470F;
          outline:none;
/* This selector is an example of how to change the appearance of a tab button
* container after the user has clicked on it to activate a content panel.
* The class "TabbedPanelsTabSelected" is programatically added and removed
* from the tab element as the user clicks on the tab button containers in
* the widget.
* As mentioned above, for our default style, tab buttons are positioned
* 1 pixel down from where it would normally render. When the tab button is
* selected, we change its bottom border to match the background color of the
* content panel so that it looks like the tab is part of the content panel.
.TabbedPanelsTabSelected {
          background-color: #CCA874;
          border-bottom-color:#CCA874;
          outline:none;
/* This selector is an example of how to make a link inside of a tab button
* look like normal text. Users may want to use links inside of a tab button
* so that when it gets focus, the text *inside* the tab button gets a focus
* ring around it, instead of the focus ring around the entire tab.
.TabbedPanelsTab a {
          color: black;
          text-decoration: none;
/* This is the selector for the ContentGroup. The ContentGroup container houses
* all of the content panels for each tabbed panel in the widget. For our
* default style, this container provides the background color and borders that
* surround the content.
* The name of the class ("TabbedPanelsContentGroup") used in this selector is
* not necessary to make the widget function. You can use any class name you
* want to style the ContentGroup container.
.TabbedPanelsContentGroup {
          clear: both;
          border-radius:0px 5px 5px 5px;
          /*border-top-right-radius:5px;
          border-bottom-right-radius:5px;
          border-bottom-left-radius:5px;*/
          -moz-border-radius:0px 5px 5px 5px;
          /*-moz-border-radius-topright:5px;
          -moz-border-radius-bottomright:5px;
          -moz-border-radius-bottomleft:5px;*/
          -webkit-border-radius:0px 5px 5px 5px;
          -webkit-border-bottom-right-radius:5px;
          -webkit-border-bottom-left-radius:5px;*/
          width: 99%;
/* This is the selector for the Content panel. The Content panel holds the
* content for a single tabbed panel. For our default style, this container
* provides some padding, so that the content is not pushed up against the
* widget borders.
* The name of the class ("TabbedPanelsContent") used in this selector is
* want to style the Content container.
.TabbedPanelsContent {
          overflow: hidden;
          width: 99%;
          margin: 4px;
/* This selector is an example of how to change the appearnce of the currently
* active container panel. The class "TabbedPanelsContentVisible" is
* programatically added and removed from the content element as the panel
* is activated/deactivated.
.TabbedPanelsContentVisible {
/* Styles for Printing */
@media print {
.TabbedPanels {
          overflow: visible !important;
          display: block !important;
          height: auto !important;
          clear:both !important;
.TabbedPanelsTab {
Here is my html mark up
<div style="margin:0 10px;"><br />
        <div id="TabbedPanels1" class="TabbedPanels">
          <ul class="TabbedPanelsTabGroup">
            <li class="TabbedPanelsTab" tabindex="0">Scenery</li>
            <li class="TabbedPanelsTab" tabindex="0">Hunts</li>
            <li class="TabbedPanelsTab" tabindex="0">Camps</li>
                      </ul>
          <div class="TabbedPanelsContentGroup">
            <div class="TabbedPanelsContent">
                      <div align="center" style="padding: 0 5px;">
                          <br />
                                      <a href="Images/scenery/big-shed.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/big-shed.gif"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/canada-053.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/canada-053.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/charlie.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/charlie.gif"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_0152.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0152.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_0378.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0378.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_0404.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0404.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                                <a href="Images/scenery/IMG_0744.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0744.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_0768.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0768.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_0797.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0797.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_0799.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0799.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/P7160592.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/P7160592.jpg" width="140" height="93
                             </a>
                    <a href="Images/scenery/IMG_0846-BW.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0846-BW.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_0981.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_0981.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_1067.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_1067.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_1118.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_1118.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/IMG_2996.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/IMG_2996.gif" width="140" height="93"  id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/P6060090.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/P6060090.gif" width="140" height="93"  id="imgGalBgrd"  />
                             </a>
                    <a href="Images/scenery/P7160567.jpg"   rel="thumbnail">
                              <img src="Images/scenery/thumbs/P7160567.gif" width="140" height="93"  id="imgGalBgrd"  />
                                   </a>
                      </div>
            </div>
              <div id="TabbedPanels2" class="TabbedPanels">
                           <li class="TabbedPanelsTab" tabindex="0">Bear</li>
                    <li class="TabbedPanelsTab" tabindex="0">Deer</li>
                    <li class="TabbedPanelsTab" tabindex="0">Elk</li>
                                                  <li class="TabbedPanelsTab" tabindex="0">Moose</li>
                    <li class="TabbedPanelsTab" tabindex="0">Goats</li>
                    <li class="TabbedPanelsTab" tabindex="0">Fishing</li>
                </ul>
                            <h3>Black Bear</h3>
                                                <a href="Images/bear/Black-bear-Dillon.jpg" title="DIllon's Black Bear"  rel="thumbnail">
                                        <img src="Images/bear/thumbs/Black-bear-Dillon.gif" width="140"  id="imgGalBgrd"  />
                                       </a>
                                          <a href="Images/bear/Black-Bear-Frank.jpg" title="Frank's Black Bear" rel="thumbnail">
                                        <img src="Images/bear/thumbs/Black-Bear-Frank.gif" width="140" id="imgGalBgrd"  />
                              </a>
                              <a href="Images/bear/Kaspers-bear.jpg" title="Kasper's's Bear"  rel="thumbnail">
                                        <img src="Images/bear/thumbs/Kaspers-bear.gif" width="140" height="93" id="imgGalBgrd"  />
                                       </a>
                                          <a href="Images/bear/IMG_0222.jpg"  rel="thumbnail">
                                        <img src="Images/bear/thumbs/IMG_0222.gif" width="140" height="93" id="imgGalBgrd"  />
                                      </a>
                          </div>
                    <h3>Grizzly</h3>
                        <a href="Images/bear/Grizzly-Lloyd.jpg" title=""  rel="thumbnail">
                            <img src="Images/bear/thumbs/Grizzly-Lloyd.gif" width="140" height="93" id="imgGalBgrd"  />
                        </a>
                        <a href="Images/bear/Grizzly-Blonde.jpg"  rel="thumbnail">
                            <img src="Images/bear/thumbs/Grizzly-Blonde.gif" width="140" height="94" id="imgGalBgrd"  />
                        </a>
                        <a href="Images/bear/Dions-Grizz.jpg" title="Dion's Grizz"  rel="thumbnail">
                            <img src="Images/bear/thumbs/Dions-Grizz.gif" width="140" height="93" id="imgGalBgrd"  />
                        </a>
                        <a href="Images/bear/Didier20004.jpg" title="" rel="thumbnail">
                            <img src="Images/bear/thumbs/Didier20004.gif" width="140" id="imgGalBgrd"  />
                        </a>
                        <a href="Images/bear/grizzly.jpg" title=""  rel="thumbnail">
                            <img src="Images/bear/thumbs/grizzly.gif" width="140" height="93" id="imgGalBgrd"  />
                        </a>
                        <a href="Images/bear/Grizzly-Freds.jpg" title="Fred's Grizzly" rel="thumbnail">
                            <img src="Images/bear/thumbs/Grizzly-Freds.gif" width="140" height="93" id="imgGalBgrd"  />
                        </a>
                    </div>
                  </div>
                            <h3> </h3>
                            <a href="Images/deer/435.jpg" title=""  rel="thumbnail">
                                <img src="Images/deer/thumbs/435.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/deer/2003-mule.jpg" title="" rel="thumbnail">
                                <img src="Images/deer/thumbs/2003-mule.gif" width="140" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/deer/Deer-Base-Camp.jpg" title=""  rel="thumbnail">
                                <img src="Images/deer/thumbs/Deer-Base-Camp.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/deer/good-day-1.jpg" title="" rel="thumbnail">
                                <img src="Images/deer/thumbs/good-day-1.gif" width="140" height="94" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/deer/IMG_0431.jpg" title=""  rel="thumbnail">
                                <img src="Images/deer/thumbs/IMG_0431.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/deer/rt-muley-003.jpg"  rel="thumbnail">
                                <img src="Images/deer/thumbs/rt-muley-003.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                        </div>
                  </div>
                            <h3> </h3>
                            <a href="Images/elk/rich-elk-04.jpg" title=""  rel="thumbnail">
                                <img src="Images/elk/thumbs/rich-elk.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/elk/042.jpg" title="" rel="thumbnail">
                                <img src="Images/elk/thumbs/042.gif" width="140" height="93" id="imgGalBgrd"  />
                        </a>
                        <a href="Images/elk/Didier2009.jpg" title=""  rel="thumbnail">
                                <img src="Images/elk/thumbs/Didier2009.gif" width="140" height="92" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/elk/elk-04.jpg" title="" rel="thumbnail">
                                <img src="Images/elk/thumbs/elk-04.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                        </div>
                  </div>
                            <h3> </h3>
                            <a href="Images/moose/Victors-moose.jpg" title=""  rel="thumbnail">
                                <img src="Images/moose/thumbs/Victors-moose.gif" width="140" height="92" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/P9020187.jpg" title=""  rel="thumbnail">
                                <img src="Images/moose/thumbs/P9020187.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/IMG_3912.jpg" title="" rel="thumbnail">
                                <img src="Images/moose/thumbs/IMG_3912.gif" width="140" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/IMG_3889.jpg" title="" rel="thumbnail">
                                <img src="Images/moose/thumbs/IMG_3889.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/IMG_0480.jpg" title=""  rel="thumbnail">
                                <img src="Images/moose/thumbs/IMG_0480.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/IMG_0478.jpg"  rel="thumbnail">
                                <img src="Images/moose/thumbs/IMG_0478.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/IMG_0025.jpg" title="" rel="thumbnail">
                                <img src="Images/moose/thumbs/IMG_0025.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/405.jpg" title=""  rel="thumbnail">
                                <img src="Images/moose/thumbs/405.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/IMG_0063.jpg" title="" rel="thumbnail">
                                <img src="Images/moose/thumbs/IMG_0063.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/moose/moose-4.jpg" title=""  rel="thumbnail">
                                <img src="Images/moose/thumbs/moose-4.jpg" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                        </div>
                  </div>
                    <h3> </h3>
                              <a href="Images/goat/yukon-dall.jpg" title=""  rel="thumbnail">
                                  <img src="Images/goat/thumbs/yukon-dall.gif" width="140" height="93" id="imgGalBgrd"  />
                        </a>
                        <a href="Images/goat/devilhoje.jpg" title="" rel="thumbnail">
                                  <img src="Images/goat/thumbs/devilhoje.gif" width="140" id="imgGalBgrd"  />
                        </a>
                    </div>
                  </div>
                            <h3> </h3>
                            <a href="Images/fishing/Bull.jpg" title=""  rel="thumbnail">
                                <img src="Images/fishing/thumbs/Bull.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/_IGP4938.jpg" title="" rel="thumbnail">
                                <img src="Images/fishing/thumbs/_IGP4938.gif" width="140" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/P3290142.jpg" title=""  rel="thumbnail">
                                <img src="Images/fishing/thumbs/P3290142.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/P3300190.jpg" title="" rel="thumbnail">
                                <img src="Images/fishing/thumbs/P3300190.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/P6170136.jpg" title=""  rel="thumbnail">
                                <img src="Images/fishing/thumbs/P6170136.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/IMGP0204.jpg"  rel="thumbnail">
                                <img src="Images/fishing/thumbs/IMGP0204.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/Kyle-Bull.jpg" title=""  rel="thumbnail">
                                <img src="Images/fishing/thumbs/Kyle-Bull.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/P7130024.jpg" title="" rel="thumbnail">
                                <img src="Images/fishing/thumbs/P7130024.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/P7200699.jpg" title=""  rel="thumbnail">
                                <img src="Images/fishing/thumbs/P7200699.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/P8100864---Copy.jpg"  rel="thumbnail">
                                <img src="Images/fishing/thumbs/P8100864.gif" width="140" height="91" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/P9070927.jpg" title=""  rel="thumbnail">
                                <img src="Images/fishing/thumbs/P9070927.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/scrapbook-pictures.jpg" title="" rel="thumbnail">
                                <img src="Images/fishing/thumbs/scrapbook-pictures.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/tobin.jpg" title=""  rel="thumbnail">
                                <img src="Images/fishing/thumbs/tobin.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                            <a href="Images/fishing/Wolv-Bull.jpg"  rel="thumbnail">
                                <img src="Images/fishing/thumbs/Wolv-Bull.gif" width="140" height="93" id="imgGalBgrd"  />
                            </a>
                        </div>
                  </div>
                </div>
              </div>
            </div>
                          <br />
                                      <a href="Images/camp/IMG_1245.jpg" title=""  rel="thumbnail">
                              <img src="Images/camp/thumbs/IMG_1245.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                                <a href="Images/camp/IMG_3014.jpg" title=""  rel="thumbnail">
                              <img src="Images/camp/thumbs/IMG_3014.gif"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/camp/IMG_3015.jpg" title=""  rel="thumbnail">
                              <img src="Images/camp/thumbs/IMG_3015.gif"   id="imgGalBgrd"  />
                             </a>
                                <a href="Images/camp/P9120211.jpg" title=""  rel="thumbnail">
                              <img src="Images/camp/thumbs/P9120211.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                    <a href="Images/camp/P9260244.jpg" title=""  rel="thumbnail">
                              <img src="Images/camp/thumbs/P9260244.gif" width="140" height="93"   id="imgGalBgrd"  />
                             </a>
                </div>
            </div>
</div>
        </div>
        </div>
        <p> </p>
        <script type="text/javascript" src="SpryAssets/SpryURLUtils.js"></script>
                    var params = Spry.Utils.getLocationParamsAsObject();
        </script>
var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1", {defaultTab: params.tab ? params.tab : 0});
var TabbedPanels2 = new Spry.Widget.TabbedPanels("TabbedPanels2", {defaultTab: params.subtab ? params.subtab : 0});
        </script>
Any help would be appreciated
Thanks Winrol
    Jan 20, 2013 11:48 PM   in reply to winrol
    Hello Winrol,
    what concerns your: "but It does not work at all in any version of IE.". My IE9 shows your website excellent in terms of appearance and function. Don't worry about the other versions, they really have hardly any significance, as you can see her e.g.:
    http://gs.statcounter.com/#browser_version-ww-monthly-201301-201301-ba r
    Hans-Günter
    Jan 21, 2013 7:01 AM   in reply to winrol
    Hi winrol,
    might be that one of your problems "the first tabbed panel are open, showing all content" we could fix here, by the help of David Powers  tutorial: http://foundationphp.com/tutorials/spry_url_utils.php by adding point 5:
    ... and for my understanding: Do you want to start a gallery or a slideshow by clicking into your images?
    Hans-Günter
    Jan 21, 2013 9:48 PM   in reply to winrol
    Hi winrol,
    now (before not, that was because I asked you) the thumbnail viewer works like a charm.
    Good luck!
    Hans-Günter
