Shaheedz
there is a huge space under the text "with in the text-box" that makes unnecessary unneeded space
Jan 21, 2013 6:17 AM
There is a huge space under the text "with in the text-box" that makes unnecessary and unneeded space and I need a method to adjust the ".eps" hight to remove that space
any suggestion except doing crop by pdf as it makes fonts errors???
    Jan 21, 2013 6:38 AM   in reply to Shaheedz
    You might want to show us a screenshot of the problem.
    Jan 21, 2013 7:35 AM   in reply to Shaheedz
    Shaheeds,
    It sounds as if you are talking about inherent parts of the typeface, which you get rid of if you otline (Type>Outline), but then you also get rid of the option of editing the text.
    http://en.wikipedia.org/wiki/Em_%28typography%29
    http://en.wikipedia.org/wiki/Descenders
    Jan 22, 2013 2:25 AM   in reply to Shaheedz
    Shaheedz,
    What is the full difference between the two live Type instances?
    The one to the left looks as if there is a number of empty lines after the italic as.
    Jan 22, 2013 3:40 AM   in reply to Shaheedz
    Then I believe there is something wrong with the left one, Shaheedz.
    Fonts, especially free ones, may fall short. Illy is more particular than most and even refuses to open certain fonts altogether, including some that may be opened in other applications.
    What happens if you try to use the font in another application, such as a word processing one?
    Jan 22, 2013 5:44 AM   in reply to Shaheedz
    If the EPS includes live text objects, the bounds are going to include the bounds of the textFrame.
    Illustrator does not provide the means by which to set a textframe to auto-fit its content. So if it's an AreaType object, you need to shrink the textframe.
    If it's a PointType object, then check it for invisible characters (ex: paragraph returns) or invisible characters and an inappropriately large leading setting (line spacing).
    JET
    Jan 22, 2013 6:05 AM   in reply to Shaheedz
    Shaheedz,
    I believe James has it with the
    This means that you may force it to work, but the font would be rather useless in most other applications, so it may be worth reconsidering a more cooperative font.
    Jan 23, 2013 5:46 AM   in reply to Jacob Bugge
    Excess leading alone will not enlarge the textFrame. That's why I said "...or invisible characters and  an inappropriately large leading..."
    JET
    Jan 23, 2013 8:07 AM   in reply to JETalmage
    That is true, James, and my quote was misleading, sorry.
    I fell straight into the short circuit of linking it with the similar Word processing issue and suggesting the solution of dropping the font as useless because of the leading.
    Feb 2, 2013 1:17 AM   in reply to Shaheedz
    I think you are right, Shaheedz, see Post #2.
    Feb 2, 2013 5:34 AM   in reply to Shaheedz
    I think this large bounding box is due to extended letters in fonts that forced the whole font to take the same hight...
    What is the font that you used in your problem example?
    JET
