Hello!
Before anything, I would like to state that I'm very new to editing with premiere elements (or editing at all).
Now, I'm having a problem with a video. I capture my clips off my screen using a program called Fraps. Once I've finished editing the video, the preview looks fine, so I click the share option and upload it to my YouTube account on PAL HD for YouTube 1920 x 1080.
Then, when I load the video on YouTube, the video haves an annoying black border surrounding it.
I have no idea how to fix this. I've tried looking it up but I haven't found anything of much use.
If you need any more details please say so and I'll post them in a response.
There are a number of challenges with using FRAPS video in Premiere Elements. It's not a good fit at all.
But the reason you're seeing black borders is because the size of your FRAPs video is different than the size and/or dimensions of your video project.
What is the exact size, in pixels, of the are or the screen you are capturing with your FRAPs program?
If the area you're capturing can be resized to 1280x720, then it would fit into a Premiere Elements video frame.
All projects edited in Premiere Elements must fit into one of its frame sizes:
1920x1080
1280x720
640x480 (or, in non-square pixels, 720x480)
If your video fits perfectly into one of these video frames, you won't have black bars around it when you output your movie.
Dealing with just the black bars, and using PrE, the best that you can do is to pick a Project Preset, with a Frame Size, as close to your FRAPS material, as is possible, and then to use the Fixed Effect>Motion>Scale to enlarge the footage, to fill the Video Frame Size. Scaling UP will slightly degrade the image, but there is no way around it.
As your 1366 x 768 has an Aspect Ratio (1.78 vs 1.777 - essentially the same), very, very close to that of 1920 x 1080, that would be my choice. Your PAR (Pixel Aspect Ratio) is going to be PAR = 1.0, or Square Pixels, so that will be what you also want. You might loose a few pixels on one side, but not such that one would ever notice.
PrE is designed to work with standard Video Frame Sizes, and offers no way to create a Custom Frame Size, like PrPro does, so you are limited to just those standard Sizes.
For some tips on FRAPS, and other video screen-cap programs, this older article might have some useful info. Note: much of the discussion IS for PrPro, and not PrE, so one has to take a few limitations into mind: http://forums.adobe.com/message/4461642#4461642
I changed the resolution of my screen to be 1280 x 720. then I recaptured the video and when I uploaded it it fit the screen perfectly.
However the resolution clearly decreased.
Is there a way to get the first capture to fit the video project? Or specify the video project to be 1366 x 768?
For every Clip Imported into the Project, and used on the Timeline, there are several Fixed Effects, that are automatically added to each Clip. Those are Motion (with Scale, Position & Rotation), and then Opacity, and Volume, if the Clip has Audio attached to it.
The Motion>Scale is what you will want to adjust. If you have multiple Clips, you can do the adjustment for Motion>Scale in the first one, then Rt-click, choosing Copy. Then, Select all other, similar Clips on the Timeline, Rt-click on those, and choose Paste Attributes. That will then apply the adjustment to the Fixed Effect>Motion>Scale to all of those.
Yes!
Finally I got it working. I just had to change the project preset to a 1080 x 720 resolution one. Then all my clips fited perfectly!
The definition problem I had was because I was exporting the files on a lower resolution preset. But strangely, changing it to the 1090 x 1080 fixed it and it still fited the whole screen.
Thanks to all of you for your help ![]()
North America
Asia Pacific
