Hi, We have an issue with publishing to RH9 Server from a RH9 project.
When we open the published file from this URL:
http://ntrobohlpd02:8080/Robohelp/server?prj=Tests_2_Entreprise_FR
The toolbar (where the TOC, index etc. icons are displayed) comes from another project:
The toolbar that should display is this one (large green and grey icons):
Why does the server show the whkin_tbars.htm from another project? Really weird. We've tried to restart the server as mentionned by Adobe tech support when I contacted them. It worked once, but will we need to restart the server every time we want to publish? Thanks
Presumably the same does not happen if you view the help from the generated location. What happens if you launch the help from the server or from the Web Administrator?
I always suggest that people manually delete all the files from the server area location before they publish their output. The publish process is unlike the generate process. It is effectively just a copy an leaves all sort of unnecessary files behind from the previous publish. By publishing to a "clean" location you know that the content is good.
You may also want to delete your browser cache. This has been known to cause confusion by displaying a cached (and therefore old) file. Let us know how you get on.
North America
Asia Pacific
