hmoore234
illustrator CS4 "out of memory" exporting to PSD
Jan 21, 2013 5:26 PM
illustrator CS4 "out of memory" exporting to PSD.
settings to write layers at 300 dpi.
worked fine a week ago, suddenly no memory?
even tried with a 3 inch square and it would not export to Photoshop.
Works fine in CS6, but I don't always have access to CS6.
Message was edited by: hmoore234
    Jan 21, 2013 8:43 PM   in reply to hmoore234
    What appearances are used? What effects? What other stuff? This error often comes up when you already use memory intense stuff like drop shadows, embedded images, 3D-ish effects or the program needs to run some color profile conversion. also content that extends far beyond the artboard borders will cause this, since AI will stil ltry to render it for export...
    Mylenium
    Jan 22, 2013 7:57 AM   in reply to hmoore234
    Impossible to tell without actualyl knowing what your settings are. I stil lthink that this issue could be related to your color management or you inadvertently attaching soemthing odd to your graphics because you may have accidentally defined something as the default appearance and it now messes up the simplest object you draw... Perhaps you can provide soem screenshots....
    Mylenium
