CSS files does not appear to link
Jan 21, 2013 8:31 PM
Tags: #background #color #dreamweaver #link #css
I have created a simple site from scratch in Dreamweaver 6 (mac) using one of the software templates and uploaded it. The header, footer and body should have a black background. The typeface and alignment are wrong. It looks to me that there is a break in the link to the css file.
The site appears fine when previewing in the browser thru Dreamweaver but when I upload the file the css does not work. I had no problem building a site and uploading it for my class (different server) but when I try to upload my own . . .
This is my site address: http://home.ca.astound.net/~m.dewilde/
I would appreciate any help.
    Jan 22, 2013 4:08 AM   in reply to dzdewilde
    are you sure, that you loaded up your style.css to your server. Searching for it with: http://home.ca.astound.net/~m.dewilde/style.css, I got this:
    @charset "UTF-8"; body { font: 100%/1.4 Verdana, Arial, Helvetica, sans-serif; background-color: #000000; margin: 0; padding: 0; color: #000; } .container { } .container { } ul, ol, dl { padding: 0; margin: 0; } h1, h2, h3, h4, h5, h6, p { margin-top: 0; padding-right: 15px; padding-left: 15px; color: #CCC; text-align: center; } a img { / border: none; } a:link { color:#414958; text-decoration: underline; } a:visited { color: #4E5869; text-decoration: underline; } a:hover, a:active, a:focus { text-decoration: none; } .header { background-color: #000000; } */ .content { padding: 10px 0; text-align: center; } .content ul, .content ol { padding: 0 15px 15px 40px; } .footer { padding: 10px 0; background-color: #000000; text-align: center; } .fltrt { float: right; margin-left: 8px; } .fltlft { float: left; margin-right: 8px; } .clearfloat { clear:both; height:0; font-size: 1px; line-height: 0px; }
    what means there must be a wrong name for it in your directory.
    I copied this from above into a new style.css and together with your source code from index.html I got this in live view:
    Hans-Günter
    Jan 22, 2013 2:05 PM   in reply to dzdewilde
    If you inspect your page with Firefox Web Developer tool (get that!) you'll see a warning:
    [13:36:48.725] The stylesheet http://home.ca.astound.net/~m.dewilde/style.css was not loaded because its MIME type, "text/html", is not "text/css". @ http://home.ca.astound.net/~m.dewilde/
    so either you have an error in your HTML (seems ok to me) or you need to add that MIME type to your webserver so that it will send the right content-type with the .css file.
    if you are on a Apache server add this to your .htaccess:
    AddType text/css .css
    /edit:
    Since you are using the HTML5 doctype you can safely omit the type="text/css" bit
    try <link rel="stylesheet" href="style.css" >
    not that I expect this to make a difference, but since the confusion seesm to be about the MIME type worth trying
    Jan 24, 2013 12:15 AM   in reply to dzdewilde
    I will be looking for a new web host soon.
    right,
    a webhost that does not support external stylesheets is not really a webhost.
    don't forget to mark helpful answers as "helpful"
