lambchopnyc
Dreamweaver adding spaces inside code....
Jan 21, 2013 9:51 PM
Tags: #dreamweaver
Dreamweaver is adding spaces inside my H1 tags and also my meta descriptions (+ probably more) and Google can't read it for SEO.
Any ideas how to resolve this and why it would be happening?  I am using CS6 on a Mac.
I've been trying to work with BoostSuite on SEO and they software will not recognize the tags because of this and it works the same as Google would to read the tags.
Here's an example:
<meta name="description" content="Biscuits by Lambchop - Sensible      treats for the sensitive dog - specializing in healthy gluten-free      dog treats. Also free of wheat, rice, corn, soy, dairy, eggs,      animal proteins and preservatives, and low in fat, sodium and      phosphorus. Biscuits by Lambchop is your  premier source for healthy treats for dogs, made with love and care for quality, in the USA.">
Actually I copied and pasted here and it looks fine, like it does in DW code view.  However if you go to the site (biscuitsbylambchop.com) and view source the spaces show up like this:
Thanks for any input!
    Jan 22, 2013 1:29 AM   in reply to lambchopnyc
    to delete these spaces you could use DW's "Find and Replace" function or detour a "normal" text processing program.
    Hans-Günter
    Jan 22, 2013 6:53 AM   in reply to lambchopnyc
    use a simple texteditor and copy your text into DW (or do this action already in texteditor). Using DW, I'll show this screenshot:
    First little green arrow: Search (Suchen): put in two spaces with the space bar
    Second little green arrow: Replace (Ersetzen): put in one space with the space bar
    Control your action, one after the other.
    Hans-Günter
    Jan 22, 2013 12:26 PM   in reply to lambchopnyc
    Which app are you copying & pasting from?  MS Office is notorious for adding junk code which you can't see in DW.  To avoid this, use Edit > Paste Special > Text only.
    Nancy O.
    Jan 22, 2013 12:38 PM   in reply to lambchopnyc
    as I said above, therefore I use a "simple" texteditor (from my German Windows) like
    and already there you could use find/replace or you copy your text into DW and use its f/r function.
    In WORD you have to use other tricks, so as Nancy said.
    Hans-Günter
