Sharvesh905535
Hindi Translation in Illustrator
Jan 22, 2013 9:24 AM
I want to translate some English words into Hindi in Illustrator. But almost everytime I do so, the spelling changes to an incorrect one in Hindi. I would like to know how to avoid this. I use google translate first to translater the word, then copy and past the word into Illustrator. I then change the font to Devanagiri Sangam MN so the Hindi characters are displayed instead of the ascii code when pasted. Is there anyway I can get this problem solved?
    Aug 6, 2013 3:54 AM   in reply to Sharvesh905535
    You could do this with a tool called Sysfilter for Illustrtator. Using Sysfilter you can extract the texts and translate with MS Word for example. And also change the fonts... HTH
    Aug 6, 2013 4:15 AM   in reply to Sharvesh905535
    Sharvesh,
    There may be conversion errors (and even translation inaccuracies/errors) in the different applications you are relying on, so it may be necessary to check everything in any case and expect the need for some corrections.
    Aug 6, 2013 7:35 AM   in reply to Sharvesh905535
    I had a similar case with a book cover done in PS. The Hindi was garbled and with spelling errors according to the translator.The solution was to enter the text in Indesign that has a World-Ready Paragraph Composer that takes care of these problems. I don't see this feature in Illustrator.
    Aug 6, 2013 8:32 AM   in reply to Sharvesh905535
    Which version?
    CC supports some Indic languages.
    Aug 6, 2013 8:36 AM   in reply to Sharvesh905535
    which version of Ai are you using? if you are using Illustrator CC you should read this page: http://helpx.adobe.com/illustrator/using/indic-support.html
    Aug 6, 2013 9:38 AM   in reply to ADBEDesigner
    Well, it's good to know that CC now has that feature. I guess is the equivalent to the World-Ready Paragraph Composer in ID? By the way I'm still on CS6.
