How do I make the video (canvas) background white instead of black in PE11?
Jan 22, 2013 11:14 AM
Tags: #background_color
I want to use a white background in the global video canvas instead of black.  How would I go about this in PE11.
Dave
    Jan 22, 2013 12:35 PM   in reply to davelalande
    In the Project Panel, click on the New Icon, and choose Color Matte. You can set that to any color, that you wish. Drag that to the Timeline, on Video Track 1, and click+drag on the Tail of that, to extend it as long a Duration, as you wish.
    Also, what we see as "black" in a Video Project, is really "transparent," but if there is nothing to show through that, it appears as black.
    Jan 22, 2013 1:58 PM   in reply to davelalande
    In Expert Mode, follow these instructions:
    Project Assets panel overview
    The Project Assets panel lets you preview source material for your projects. Select the Expert view and then click Project Assets.
    You can view the contents of a project using the list view or the grid view. Use the panel options menu to switch between the views.
    The grid view displays a snapshot of the video you imported into the project. The Project As
    For Black Video, or Color Mattes, follow these instructions:
    Create and add a black video clip
    You add black video clips to separate multiple movies or to create pauses in a movie. You can also use a black video clip for a title.
    1.  Click Project Assets.
    2.  In the Project Assets panel, click New Item from the panel options and choose Black Video.
    Create a colored matte for a background
    You can create a clip consisting of a full-frame matte of solid color, which you can use as a solid background for titles or animated clips.
    Brightly colored mattes can serve as temporary backgrounds to help you see transparency more clearly while you adjust a key effect.
    2.  In the Project Assets panel, click New Item from the panel options and choose Color Matte.
    3.  Choose a color in the Adobe Color Picker dialog box, and click OK.
    A color matte clip is placed into both the Project Assets panel and the Expert view timeline.
    Good luck, and hope that helps,
    Jan 23, 2013 8:09 AM   in reply to davelalande
    Great news!
    With each version of PrE, Adobe changes a few names, and even locations of common operations, so it's tough to keep up with exactly what something is called, version to version.
    Glad that you found it, and that it worked for you.
    Another, though somewhat convoluted route, would be to create a New Title, and then create a Full-Frame Shape, of the desired color, and probably with no Stroke. However, I find Color Matte to be like "one stop shopping."
    Happy editing,
