tconkling
Flash Builder 4.7 refactoring is broken
Jan 22, 2013 12:51 PM
Tags: #error #flash_builder #4.7
I'm unable to rename methods or classes in Flash Builder 4.7. Attempting to refactor gives this error:
"An unexpected exception occurred while performing the refactoring. See the error log for more details."
This happens in all my projects. I've recreated my workspace from scratch and the error persists.
I recently overlaid the AIR 3.6 SDK in Flash Builder. I tried reverting to AIR 3.5, which I'd backed up, but that did not fix the problem either.
The error in the log follows:
java.lang.reflect.InvocationTargetException
          at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
          at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.run( RefactoringWizardDialog2.java:331)
          at org.eclipse.ltk.ui.refactoring.RefactoringWizard.internalPerformFinis h(RefactoringWizard.java:605)
          at org.eclipse.ltk.ui.refactoring.UserInputWizardPage.performFinish(User InputWizardPage.java:153)
          at org.eclipse.ltk.ui.refactoring.RefactoringWizard.performFinish(Refact oringWizard.java:678)
          at org.eclipse.ltk.internal.ui.refactoring.RefactoringWizardDialog2.okPr essed(RefactoringWizardDialog2.java:455)
          at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:472)
          at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
          at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java: 240)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
          at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
          at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3974)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
          at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
          at org.eclipse.jface.window.Window.open(Window.java:801)
          at com.adobe.flexbuilder.editors.derived.refactoring.FlexOpenRefactoring WizardOperation$1.run(FlexOpenRefactoringWizardOperation.java:144)
          at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
          at com.adobe.flexbuilder.editors.derived.refactoring.FlexOpenRefactoring WizardOperation.run(FlexOpenRefactoringWizardOperation.java:157)
          at com.adobe.flexbuilder.as.editor.ui.actions.refactoring.SimpleRenameRe factorAction.run(SimpleRenameRefactorAction.java:78)
          at com.adobe.flexbuilder.as.editor.ui.actions.refactoring.RenameRefactor Action.run(RenameRefactorAction.java:89)
          at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
          at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler.java:185)
          at org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execute(LegacyH andlerWrapper.java:109)
          at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
          at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(Para meterizedCommand.java:508)
          at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(Handle rService.java:169)
          at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(Workben chKeyboard.java:468)
          at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(WorkbenchKeyboar d.java:786)
          at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEvent(Workbe nchKeyboard.java:885)
          at org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequenceBindi ngs(WorkbenchKeyboard.java:567)
          at org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(WorkbenchKeyb oard.java:508)
          at org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter.handleEv ent(WorkbenchKeyboard.java:123)
          at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1069)
          at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4127)
          at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1494)
          at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1490)
          at org.eclipse.swt.widgets.Canvas.sendKeyEvent(Canvas.java:463)
          at org.eclipse.swt.widgets.Composite.keyDown(Composite.java:594)
          at org.eclipse.swt.widgets.Display.windowProc(Display.java:5473)
          at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
          at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:220)
          at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:2092)
          at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2252)
          at org.eclipse.swt.widgets.Display.windowProc(Display.java:5535)
          at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:498 9)
          at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5138)
          at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
          at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication. java:128)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3610)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja va:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:667)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashB uilderApplication.java:79)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:196)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:344)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:597)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.NullPointerException
          at org.eclipse.core.runtime.Path.isPrefixOf(Path.java:632)
          at org.eclipse.core.internal.localstore.FileSystemResourceManager.resour ceForLocation(FileSystemResourceManager.java:286)
          at org.eclipse.core.internal.localstore.FileSystemResourceManager.contai nerForLocation(FileSystemResourceManager.java:266)
          at org.eclipse.core.internal.resources.WorkspaceRoot.getContainerForLoca tion(WorkspaceRoot.java:120)
          at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGatewa y.loadProject(SearchIndexGateway.java:414)
          at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGatewa y.loadProject(SearchIndexGateway.java:422)
          at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGatewa y.createQuery(SearchIndexGateway.java:376)
          at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGatewa y.getOccurrences(SearchIndexGateway.java:188)
          at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGatewa y.access$4(SearchIndexGateway.java:172)
          at com.adobe.flexbuilder.codemodel.internal.as.indices.SearchIndexGatewa y$SearchIndex.getOccurrences(SearchIndexGateway.java:556)
          at com.adobe.flexide.refactoring.core.ASRenameProcessor.checkFinalCondit ions(ASRenameProcessor.java:199)
          at com.adobe.flexide.refactoring.core.VariableRenameProcessor.checkFinal Conditions(VariableRenameProcessor.java:139)
          at org.eclipse.ltk.core.refactoring.participants.ProcessorBasedRefactori ng.checkFinalConditions(ProcessorBasedRefactoring.java:224)
          at org.eclipse.ltk.core.refactoring.CheckConditionsOperation.run(CheckCo nditionsOperation.java:85)
          at org.eclipse.ltk.core.refactoring.CreateChangeOperation.run(CreateChan geOperation.java:121)
          at org.eclipse.ltk.core.refactoring.PerformChangeOperation.run(PerformCh angeOperation.java:209)
          at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344 )
          at org.eclipse.ltk.internal.ui.refactoring.WorkbenchRunnableAdapter.run( WorkbenchRunnableAdapter.java:87)
          at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(Modal Context.java:121)
    Jan 23, 2013 12:08 AM   in reply to tconkling
    confirm this issue, i can reproduce by try to refactoring by move folder to other folder e.g.
    at first
    /com
    /something/manythinghere
    then and want to refectoring to...
    /com/somthing/manythinghere
    then error throw up, 100% reproduce able here.
    Jan 28, 2013 12:30 AM   in reply to katopz@sleepydesign.com
    I just overlaid the 3.6 SDK and tried reproducing the issue, with the steps mentioned above. But refactoring seems to work fine for me.
    Are you using some other plugins with Flash Builder 4.7 ?
    Can you try switching to a new workspace and try the scenario in a newly created project?
    If it still happens. Kindly provide the steps to reproduce the issue and we'll look into it. Thanks.
    Jan 28, 2013 9:11 PM   in reply to Guriya Kalyani
    Hi Guriya,
    i also can't reproduce this at my home computer, but 2 of office computers still have this issue, seem like it happend only will deep nested package in some certain case
    fyi : i had http://sourceforge.net/projects/flexformatter/
    installed all of 3 computers
    btw, make sure you check "Include subpackages" while moving to reproduce (Just in case you didn't check it) and try it with more complex and deep neted folder e.g.
    i attach reproducable project here http://www.sendspace.com/file/cmltm8
    and here's how to reproduce (move "data" folder to "com" folder and checked "Include subpackages")
    Thanks for assit
