"CAHeadless Debug Event" Error
Jan 22, 2013 11:04 PM
Tags: #error
Greetings,
I am getting the following error popping up in a dialog box about every five minutes:
CAHeadless has encountered an error.
[..\..\Src\Clip\VideoClip.cpp-276]
I have to click "Continue" to make it going away temporarily.
As a workaround, if I click Edit > Preferences > Media-Analysis, and clear the "Analyze Media for Smart Tags Automatically" box, the errors stop. But I was wondering if here was an actual fix for this error, instead of just a work-around which I discovered.
Shane.
Photoshop Elements 11.0
Windows 7 Home Premium SP1 64-bit
Message was edited by: c_Shane
    Jan 22, 2013 11:07 PM   in reply to c_Shane
    Please try creating Organizer prefs from scratch.
    To re-create the Elements Organizer preferences file:
    - Close the Elements Organizer.
    - Rename the psa.prf file (for example, to psa.old) in C:\Users\[your user name]\AppData\Roaming\Adobe\Photoshop Elements\10.0\Organizer.
    Open the Elements Organizer.
    Now try turning on the Media Analysis prefs and see if it makes a difference.
    Andaleeb
    Jan 22, 2013 11:39 PM   in reply to c_Shane
    Try the location : %appdata%\Adobe\Elements Organizer\10.0\Organizer
    and rename both psa.prf as well as status.dat
    Andaleeb
    Jan 23, 2013 9:44 PM   in reply to c_Shane
    Since you are using version 11, please delete the file under 11.0 folder.
    regards,
    vaishali
    Jan 23, 2013 11:21 PM   in reply to c_Shane
    They must not be taking a lot of space. However if you have uninstalled PSE9 and PSE10, you can safely delete these folders.
    Andaleeb
    Jan 24, 2013 9:23 PM   in reply to c_Shane
    C_Shane,
    You are right. This is a known issue with Auto Analyzer. The workaround as of now if to uncheck the options to generate smart tags by turning OFF auto analysis.
    Regards,
    vaishali
