airplus_peter
Color finesse crashes AE6
Jan 23, 2013 7:52 AM
Hi Community, i use ProdStudio CS6 with the Color Finesse 3LE Plugn. If i want to use it, it asks for Company Name and Name. If i click ok AE6 crashes .
All Updates installed, uninstall, re-install..... nothing helps and i have the pink lines in my Project. Please help!!! Thank you, Peter
    Jan 23, 2013 4:51 AM   in reply to airplus_peter
    What system? If this is windows, you may have a permissions problem with your Registry. Try to run as admin.
    Mylenium
    Jan 23, 2013 5:20 AM   in reply to airplus_peter
    Check your security stuff. Something is definitely blocking your registry access and possibly invocation of the custom external plug-in stuff. Providing the full error messages might offer some clue to the exact cause (if there is more info).
    Mylenium
    Jan 23, 2013 11:12 AM   in reply to airplus_peter
    I concur with Mylenium: it's most likely a Registry protection issue.
    One thing to test is invoking the Color Finesse plug-in, then when it asks for user name/org, click Cancel. This will put it into trial mode so you'll get pink lines over your image, but it won't be attempting to write the name/org info to the Registry.
    If it works in trial mode, then that again points the finger at the Registry being locked/protected by your security software.
    Bob Currier
    Synthetic Aperture
    Jan 24, 2013 9:32 AM   in reply to airplus_peter
    Glad to hear things are working for you now.
    We'll investigate why a failure to write to the Registry causes a crash. Worst case should be that CF stays in trial mode.
    Thanks for reporting back.
    Bob Currier
    Synthetic Aperture
