After buying Photoshop CS6 Extended due to it's amazing 3D options I realized my videocard sucked because it is a CSU and not a GPU as required.
So I looked up what the requirements are to enable the GPU options and it stated that it requires a OpenGL 2.0 and Shader Model 3.0.
I have been searching for a videocard that matches exactly that without any result (I live in a country the size of a peanut that doesn't sell a 2.0 and a 3.0).
But I did find shader models of 5.0 and OpenGL 4.1 and I wanted to know if that is acceptable too.
Are the OpenGL 2.0 and Shader Model 3.0 the minimum requirements and can I go higher?
Or will Photoshop Extended not enable that GPU option if I do go above the requested OpenGL 2.0 and Shader Model 3.0???
[Removed personal information]
Thanks a lot !!!
Message was edited by: sinious
Those are minimium requirements. Also recommend a min. of 1 gig of VRAM if going 3D.
Here is a website that ranks video cards. A rank of 1000 is excellent, and about all that is needed. http://www.videocardbenchmark.net/
Hi, Thank you so much for answering so quickly.Because Adobe help forum had a list with different types of cards, I thought: it had to be that..So when I started searching and searching and couldn't find a card that matches that... I got worried. But thank you so much for answering !!
[ unnecessary quoting removed by admin ]
North America
Asia Pacific
