When updating modified links, my links don't come in at the same size as the image that is on the screen and they are not placed in the same position as the image on the screen. I know that the image on the screen is just a screen shot of the image that was placed, and when I am relinking the image it is to the same file that I use all the time?
This happens on a daily basis and I will have to delete the image and replace and resize to get it back to the way it was supposed to be?
Any help on how to make sure the image comes in just like it appears on the screen when all I am doing is relinking to a modified version of the file?
I share files with a customer of our via cubby, we share the files so they do not changes on a regular basis. We have the same images and we link and use the same images, the images are not being edited between the two people using them. They reside in one place and we both use the images from that common place. When the file is opened it has to be edited in photoshop, but has not been modified since november 2012 and it still tells me that I need to update the modified links?? So when I go to relink the file that is when I am running into the problem. It does not come in the same size nor place the same position as originally set.
Crop option is set during import, and it's sticky until changed, so I'm not sure what happens on relink if the options are changed in between the original placement and the relink. I would suggest that instead of using Relink next time use the Place command, show the crop options, and set them to Art or Bounding Box and see what happens. My guess is that's wat was set initially, and the replacement image was cropped to Media.
Actually, I have a better idea. Make a new file and place that PDF into the new file, showing the import options and set the crop to Art or Bounding box as suggeted above, then go back tothe other file and relink. If resetting the crop otion is going to do anything, it will have done it when you imported into the other file. You can close that new file without saving.
North America
Asia Pacific
