Is anyone having issues with CS6 occasionally not opening files after closing the first file opened?
This issues corrects itself after rebooting the app and seems to occurs sporadically.
- MacBook Pro 2012
- OS 10.8.2
- 8 GB RAM
- Illustrator CS6 v16.2.0
This happens when you try to drag-and-drop onto icon in dock, double clicking on file or using the open command in AI.
I'll give your solutions a try when it starts acting up again and let you know. Problem is this is sporadic so it started working fine after rebooting later this morning
Thanks!
I am having the same issues. I haven't noticed anything about 'after closing the first file opened'. It just seems to happen after about a half an hour, no matter what. I can use Illustrator CS6 for only so long and then it won't open any more files and I have to close it down and restart it. And these are files created in CS6. And as you said, it happens whether I double click the file or use the open command. Very frustrating. I thought it was a glitch in the software or are we the only two having this problem?
I'm working on a Mac Pro OSX v10.7.4
Illustrator CS6 - v16.0.0
Machogg:
For me, it turned out to be a font issue. If the AI file contains a font that is not loaded in your Font Book or, in my case, Suitcase Fusion 4, then this will cause AI to crash. Once the font is loaded or activated (or removed from the AI file), everything works as it should.
Hope this helps!
I don't think that's what's causing mine, as I'm generally opening a series of files all with the same fonts. Thus the fonts are there and open because I've already worked on several files with no problem. If it works on one it should work on the others, you'd think. But thanks for the info. I will watch next time and see if there's any correlation. Thanks so much for the quick response. I'm jumping on late in the game here and didn't expect to hear back, especially not so soon.
I had the same problem and someone on the forums here said to try repairing permissions in safe mode. So... I ran through all the disk utility functions in safe mode, including breaking all program links. I downloaded Onyx and did all the maintenance on my Mac and it went away for a week or so. Then the last thing I tried is upgrading Suitcase Fusion to the latest version. It hasn't done it since (two weeks).
Ok, thanks vlaming01. I'll give that a go. Although today I'm trying to get ready for a title meeting and have been working since early this morning in Illustrator. I realized when your message came in that it hasn't done it once today. I know...I shouldn't say that out loud. Too much to hope that it healed itself. I'm currently using FontXplorer and thought perhaps that was the problem, but two of you have mentioned Suitcase, so I guess not. I'll try your suggestions. Thanks to all!
North America
Asia Pacific
