Hi, I have a different post regarding this, but I wanted to create a couple blank files to test this with. I know IE 8/7/6 are phasing out but there are still alot out there that use these browsers. On my site the code I have works in every browser but ie6/7/8. So I have created 3 html files temp1. temp2.html and temp3.html. To try to find out where my problem is. I have followed some other posts in this site but they don't seem to work. With Temp3.html I get the following error. Spry.Widget.TabbedPanels' is null or not an object.
I have tried to change the link to the labs.adobe.......tabbedpanel.js file but this never work either.
Temp2.html - http://www.alpinevalleyoutfitters.ca/temp2.html
This file is bare bones tabbed panel within a tabbed panel. Just changed the colors. No rounded corners and no spryutils.
Tabs all work fine. Hover, active tab colors all work as they should. All is good.
Temp1.html - http://www.alpinevalleyoutfitters.ca/temp1.html
This file is a copy of the above all I did was add pie.htc to the css to get rounded corners. Well I got the rounded corners, but now I can't do anything. The tabs do not work at all.
Temp3.html - http://www.alpinevalleyoutfitters.ca/temp3.html
This is a the standard DW6 spry tabbed panels inserted but with spryUtils added, as I want to be able to acces a subtab from another page. With spryutils added all tabs are open and nothing works.
Any advice would be greatly appreciated.
Thanks Winrol
Don't use Spry. Adobe abandoned it.
http://blogs.adobe.com/dreamweaver/2012/08/update-on-adobe-spry-framew ork-availability.html
There are better widgets available:
Nancy O.
North America
Asia Pacific
