More questions about drag and drop and depth
Jan 23, 2013 7:09 PM
Ok team,
so I know my drag and drop code is probably "sticking" on the mouse up event because there is something in front of the object..
I am trying to implement the numChildren code to bring the object being dragged to the front..
SO I am adding this code inside each draggable answer...
addEventListener(MouseEvent.MOUSE_DOWN, changedepth);
function changedepth(event:MouseEvent):void{
this.parent.setchildIndex(this, this.parent.numChildren-1)
ok so that part is ok, but my project is quite complex, so now when it goes onto the next section or resets itself there are children out there that are not behaving themselves..
So now I want to put something like this
addEventListener(MouseEvent.MOUSE_UP, removechild);
function removechild(event.MouseEvent){
this.parent.removeChild(-1);
but of course this doesnt work... any ideas?
Cheers for your help
Sub
    Jan 23, 2013 7:16 PM   in reply to subtlefly72
    You should assign the MOUSE_UP listener to the stage so that it is object independent.  If you need to know which object was being dragged then store a reference to it in a variable.
    Also, the removeChild() method argument needs to be a DisplayObject, not a number
    Jan 23, 2013 9:15 PM   in reply to subtlefly72
    There are many ways to do what you want, but the basic ideas that Ned gave are what you need.
    You want the mouse down handlers on the things you want to drag.
    You wan the mouse up handler on the stage because you might release the mouse not over the thing you are dragging.
    If you want to put something back to the depth/stacking order it came from you will need to keep track of the layer it came from.
    You can't use code that doesn't do what you want just because you want it to do something different. Flash does what we tell it, not what we want!
    I can't find anything regarding childindex. If it was a built in property or method it would probably be childIndex. There is a childIndex property in the XML class, but I don't think that is what you want.
    Create a new flash file (with a stage 1000 x 800) add this code and give it go.
    import flash.display.Sprite;
    import flash.display.Graphics;
    import flash.text.TextField;
    import flash.events.Event;
    import flash.events.MouseEvent;
    import flash.display.MovieClip;
    var home:MovieClip=this;
    var nunItems:int=4;
    var i:int;
    for(i=0;i<nunItems;i++){
              var s:MovieClip=new MovieClip();
              var g:Graphics=s.graphics;
              var t:TextField=new TextField();
              t.name="field";
              t.autoSize=TextFieldAutoSize.LEFT;
              t.selectable=false;
              s.mouseChildren=false;
              s.addChild(t);
              var val:Number=((0x80+0x80*Math.random())<<16)+((0x80+0x80*Math.random()) <<8)+((0x80+0x80*Math.random()))
              g.beginFill(val);
              g.drawRect(-40,-40,80,80);
              addChild(s);
              s.x=Math.random()*800+100;
              s.y=Math.random()*600+100;
              s.addEventListener(Event.ENTER_FRAME,handleFrame);
              s.addEventListener(MouseEvent.MOUSE_DOWN,handleDown);
    function handleDown(e:MouseEvent){
              var s:MovieClip=e.target as MovieClip;
              s.originalDepth=getChildIndex(s);
              addChild(s);
              s.startDrag();
              stage.addEventListener(MouseEvent.MOUSE_UP,handleUp);
    function handleUp(e:MouseEvent){
              stage.removeEventListener(MouseEvent.MOUSE_UP,handleUp);
              stopDrag();
              addChildAt(s,s.originalDepth);
    function handleFrame(e:Event){
              var s:Sprite = e.target as Sprite;
              var t:TextField= s.getChildByName("field") as TextField;
              t.text=home.getChildIndex(s).toString();
    Jan 23, 2013 10:37 PM   in reply to Rothrock
    This made my day:
    Arrgh this is killing me!
    s there anything that I can do ?
    (in a simple way)
    Response from you:
    I see what you did there
    Jan 24, 2013 6:38 AM   in reply to subtlefly72
    That is a really important lesson about debugging. The problem is what it is. It isn't what we want it to be. This goes with my other piece of advice: Flash does what we tell it to do, not what we want it to do. Keep those both in mind
