jquery slider effect to fade
Jan 24, 2013 4:10 AM
Could someone help me with my problem:
I have a site that I made using a Business Catalyst template called Adora, and there is a slidehow called AnythingSlider. The slider has a Swing effect that swings pictures and I would  like to change that into Fade effect.
Now I have no knowledge of jquery. Script on the Template looks like this:
<script type="text/javascript" src="/js/jquery.anythingslider.js"></script>
                                                  $(function(){
                                                            $('#slider1').anythingSlider({
        startStopped    : false, // If autoPlay is on, this can force it to start stopped
        hashTags        : false,
        toggleArrows    : false,
        buildArrows     : false,
        enablePlay      : true,      // if false, the play/stop button will still be visible, but not clickable.
        autoPlayLocked  : false,  // If true, user changing slides will not stop the slideshow
        resumeDelay     : 10000, // Resume slideshow after user interaction, only if autoplayLocked is true (in milliseconds).
        easing          : "swing",   // Anything other than "linear" or "swing" requires the easing plugin
        delay           : 4000,      // How long between slideshow transitions in AutoPlay mode (in milliseconds)
        animationTime   : 900,       // How long the slideshow transition takes (in milliseconds)
        onSlideComplete : function(slider){
        // alert('Welcome to Slide #' + slider.currentPage);
            </script>
It says there: Anything other than "linear" or "swing" requires the easing plugin,
and I have found several different plugins, copyed the js file to my site, linked it to my Template file
(<script type="text/javascript" src="/js/jquery.easing.js"></script>,)
changed the easing "swing" to whatever I have found in the plugin js file, like "easeOutQuad".
But I cannot get it to work. Could anyone help me out here and tell me what am I doing wrong?
Thanks in advange!
    Jan 24, 2013 6:07 AM   in reply to Elisa WD
    I don't know this particular jQuery slide show but there's literally dozens of them out there.
    If you get stuck just do a search on Google. If its just a simple fade effect you need then maybe this one:
    http://jquery.malsup.com/cycle/
    Jan 24, 2013 10:01 AM   in reply to Elisa WD
    Change this:
    to this:
    easing          : "linear",   //
    Save file & upload to server.  That may be all you need.
    If you want to use other easing effects, you'll need to refer to the easing.js documentation.
    http://gsgd.co.uk/sandbox/jquery/easing/
    Nancy O.
    Jan 25, 2013 9:54 AM   in reply to Elisa WD
    How about showing us a link to your page?
    Nancy O.
    Jan 28, 2013 10:23 AM   in reply to Elisa WD
    I recommend you read the documentation for your plugin
    http://css-tricks.com/anythingslider-jquery-plugin/
    Nancy O.
